temp prob
Old May 7, 2008 | 12:08 PM
orion88's Avatar
orion88
Default temp prob
hi guys
got an rs and the wire from the block the single push on wire was disconnected so i put this on and the needle went straight to the top.
wen i take it of i have no temp readout
i must point out that the fan switch has been taken of and replaced wit an in car switch but i need to know how hot my cars running any ideas folks?
Old May 8, 2008 | 12:57 PM
The temp sender is dicky, need a new one.
The fact that the gauge goes to the top shows the gauge is working ok.
The FAN switch has nothing to do with the temperature gauge, I would get it sorted with a new fan(correct) switch.
What RS is it ?, it sounds like it had overheating probs in the past that someone tried to cover up to sell the car.
Old May 8, 2008 | 03:54 PM
orion88's Avatar
orion88
and i bought it lol
yea the head went a day after having it but is fixed now and this temp things doing my nut in.i think he bypassed the whole fan system and wired a switch to the fan and batterry and thats it
Old May 8, 2008 | 06:12 PM
Easy to fix, just use the original wires if you can find them, if not wire in a seperate fan circuit, like cossie owners do, just need a SPST, relay, holder a bit of wire and crimps.
Most relays a re to DIN standard so will be marked thus,
87 = FANS
30 = LIVE(to relay from battery or ignition), depending on whether you want it able to run with ignition off or not, BEST from battery through fuse.
85 = NEGATIVE
86 = SWITCH, ie fan switch, so that one side of the fan switch has a(PERMANENT) live, then the other side of the fan switch(output) goes to 86 to switch it.
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
gcfcos
88
Sep 15, 2015 03:48 PM
Ben26
Sep 3, 2015 07:55 PM
