miss fire ? 3 bar map sensor
Old May 7, 2008 | 07:23 AM
rhys8's Avatar
rhys8
Default miss fire ? 3 bar map sensor
hi i just changed every thing over in my 2wd saf to run stage 3 but when you give a sudden bit off throttle it miss fires, should all 3 bar map sensors have a vacum pipe off them and if so where does it go 2 as i think the one i got sold aint a 3 bar many thanks
Old May 7, 2008 | 07:35 AM
Phil2002's Avatar
Phil2002
Yes they should all have a vacum hose and the hose will go to the inlet manifold.
MAP= Manifold absalute pressure.
Phil2002's Avatar
Phil2002
I think most 3 bar map sensors are grey in colour too.
Old May 8, 2008 | 12:41 PM
rhys8's Avatar
rhys8
Thanks i manage to sort it out it had the standard map sensor on it still i got given a throttle postion sensor and was told is was the 3 bar the cu*t lol
Old May 8, 2008 | 12:42 PM
Make sure it is mounted correctly on the proper bracket so it looks upside down, ie the terminal plug goes upwards into it, and the pipe where the vaccy pipe goes points down.
DixieTheKid
11
Jun 6, 2020 11:20 AM
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
tib2220
Sep 14, 2015 12:33 PM
hopper350
Sep 4, 2015 12:53 AM
