poybushes re fittin problems
Old May 6, 2008 | 06:54 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default poybushes re fittin problems
i have a series 2, and having difficulty gettin the big polybush in the rear wishbones rest go in. i have de-flex. anyideas?
Old May 6, 2008 | 08:36 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
if you have cut away the old bush they should go in easy!
Old May 6, 2008 | 09:39 PM
iansoutham's Avatar
iansoutham
OCD Victim
If you are having trouble putting the bush into the actual arm itself, then try a little bit of silicone spray. I had that trouble with the arms on the Cabby and just sprayed a little bit of that on the bushes, then gently tapped them in with a dead-blow hammer. Did the same when fitting them to the car as they were nice and tight there as well.
Old May 7, 2008 | 07:03 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
they seem a bit to big fot the arm is this normal?
Old May 7, 2008 | 07:06 PM
orion_crazy_carl
orion=mini saff
should be a tight fit!
Old May 7, 2008 | 08:43 PM
gup's Avatar
gup
ive got this problem too and in a pic it looked liked that some one had taken the couter metal sleeve off and pushed the bush in if that makes sense
Old May 7, 2008 | 11:20 PM
boothy's Avatar
boothy
i had the same prob the old bush has a metal sleeve in it looks like its part of the wishbone but will hammer out with big flat head
Old May 7, 2008 | 11:24 PM
rst in breaking's Avatar
rst in breaking
put mine in with a vice no problems, make sure you def have the right ones as there is 2 types as i had the wrong ones, early mk3 ones are larger, i had this prob so had to change them
Old May 8, 2008 | 04:40 PM
sm's Avatar
sm
when i fitted my powerflex bushes to my s2 i had to cut the metal sleeve in 2 then hammer and chisel the cut forcing the sleeve and bush out of ethier side
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
