fitting solid beam mount (cossie)
Old May 2, 2008 | 05:26 PM
rinus_2005's Avatar
rinus_2005
Question fitting solid beam mount (cossie)
Hi, i have a pair solid beam mounts laying around, and was about to fit them.
However when lowering the beam i noticed there is a short piping sticking out the chassisrail. Do i have to grind those down so the metal bush touches a larger area (so more stable ) or should it rest on the short pipe sticking out?
Rinus
Old May 3, 2008 | 07:17 AM
Jay,'s Avatar
Jay,
Sponsor
if ur talking about the short pipe on the top of the top part of the mount that should fit inside the chassis plate
Old May 3, 2008 | 11:26 AM
As above it acts as a spacer, obviously it has got jammed onto the chassis area where normally it stays put in the inside of the bush.
Old May 6, 2008 | 07:02 PM
rinus_2005's Avatar
rinus_2005
no that's not what i mean. the polybush including the long inside the bush came out fine.
That pipe should indeed go into the chassis. But it's the bigger pipe that acts as a spacer so you don't squeese the chassisrail that sticks out a bit.
otherwise i'll make a pic of it by tomorrow
jessie_rs
11
Jun 3, 2019 04:57 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
