wat else(enigine swap)
Old May 2, 2008 | 12:52 AM
mk2FEZ's Avatar
mk2FEZ
Default wat else(enigine swap)
hi i asked a while bk if a 1.6 cvh wud go into a 1.1 mk2 fez without must hassle ive now bought the engine and am waiting to fit it, but the engine was cut out of the old car so i only have half of the driveshafts left and i am unsure wether i can use the existing ones (1.1) because i
1. dnt no if they'll fit
n
2. if they do fit dnt no if they'll be up to the challenge
if nt then wud i have to buy xr2 1s and if i did wud they fit into the existing hubs?
also does ne one no how i can upgrade the brakes cheaply? can i fit sum off another ford for instance, or wud it be a case of buying better aftermarket brakes?
any advise wud be much appreciated as this is the first time ive tryed an engine swap and its on my first car so i dnt want to make a right mess of things if i can help it!!
Thanks
Old May 27, 2008 | 04:27 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Driveshafts need replacing, hubs 2, They dont fit and wont be up to the challenge, brake-wise i think st24,s might do,cossies mite (i got them on my mk3) or just some 2.0litre escort brakes should do
Old May 29, 2008 | 05:01 PM
fonfe's Avatar
fonfe
but st24/cossie ones will only fit under 15" wheels or larger.
personally for the money id just get some 2nd hand xr2 setup or erst II ones
bobsworth
77
Mar 24, 2016 09:30 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
cossie brad
Sep 29, 2015 02:38 PM
grishenko45
Sep 9, 2015 12:58 PM
