ZVH Rods
Old May 1, 2008 | 08:05 PM
bad boy rs's Avatar
bad boy rs
Default ZVH Rods
Hello people
Im running a 2.1 zvh in my series 2, its got ross racing forged pistons with standard rods
Im thinking more power
What is the safe limit on zetec rods ? im thinking about puting some steel jobbies in
Old May 1, 2008 | 08:23 PM
rst in breaking's Avatar
rst in breaking
people have run 300bhp ok which is surely more than enough for a fwd car?
Old May 1, 2008 | 10:01 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
iv heard 250 is the limit!
so if you are goin more the change the rods mate!
Old May 1, 2008 | 10:03 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
its 250 for cvh rods
Old May 1, 2008 | 10:43 PM
NEWTON's Avatar
NEWTON
300 zvh rod (standard)
Old May 2, 2008 | 09:35 AM
rst in breaking
ian howell told me he hasnt tested them over 300 but one has never failed at that if thats of any help?
Old May 2, 2008 | 12:39 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
i know of a failure at 300bhp, would not go above this myself
Old May 2, 2008 | 04:31 PM
bad boy rs's Avatar
bad boy rs
Thanks for the info
if 300 is the limit then i may get jamsport to tweek the boost up to say 20-22 should see 265-70 then...
Prob get bored of that though
Old May 2, 2008 | 09:23 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
What spec is your ZVH?
Reason I ask is im going to build one soon and just wondering what to expect power wise
Old May 2, 2008 | 11:02 PM
bad boy rs's Avatar
bad boy rs
dta managment, stage 3 head with cvh35, dark greens, t34, 500 cooler and a few other bits
To be honest mate i bought the lump of a mate as my 1600 went bang, but if i was to do it again i would go down the full zetec route
Dont get me wrong im more than impressd with the zvh and it goes like fuck but you could get so much more from the full zetec
Old May 3, 2008 | 07:09 PM
DazC's Avatar
DazC
From this information, this makes 300 bhp above the limit of the rods. 300 bhp is the breaking point of the rods. I'd advise you impose a 20 or 30 bhp defecit to give you some form of protection against snapping them.
Old May 4, 2008 | 07:00 PM
frsjon's Avatar
frsjon
ive seen standard zetec rods break at 270 bhp turbo'd and 180 bhp n/a...
Old May 6, 2008 | 07:38 PM
bad boy rs's Avatar
bad boy rs
Oh shit didnt realsie that could be that weak, looks like im keeping the power as it is
Old May 6, 2008 | 09:32 PM
DazC's Avatar
DazC
That would make you safe useful power output around 250 ish then!!!
Stay where you are with you power output!!
Old May 7, 2008 | 12:44 PM
G2RSR's Avatar
G2RSR
Bodybuilding
that don't mean nothing tho mate
i have seen a cvh rod fail at 167 bhp but it does not mean its the rods limit
a lot of failures can be caused by other factors ignition timing fueling revs etc
i have seen a steel rod bend at 265 bhp because of too much ignition
my mates had 301 bhp with zetec rods with arp rod bolts fitted for about 2 years no problems
Old May 7, 2008 | 01:38 PM
Turbocabbie
Top Cab !!
Obviously many things can effect a rod however when determining a 'safe' limit you can be pretty sure will not cause you problems what do you personally believe is the 'safe' point of the standard zetec rod where you are fairly safe to not to consider failure.
I think its about 260bhp myself, not for one moment am I suggesting authority, only thats the happy zone for me regarding standard zetec rods
Old May 7, 2008 | 03:39 PM
Badman38's Avatar
Badman38
300 is the limit so far on standard its not the power which breaks the rods look at revs ignition etc my last zvh was 310bhp plus i use to run 70 shot of nitrous but i only rev to 6000 never needed to rev more with nitrous..
sean
Old May 7, 2008 | 07:58 PM
RSricRS's Avatar
RSricRS
Long live the ford RS'S
stick to 250-260bhp mate when you start going above that its gets silly and the power from 1st to 3rd becomes useless pluss it will be more reliable!! a good honest 250bhp zvh will do impressive 1/4 miles and there a machine an half at that mate, maybe start looking into transmission etc getting all the power to the floor instead of wasting power and money! am sticking to 260 when mines done, but who honestly knows the limit of zetec rods.... answer: Depends how you drive SIMPLE!
Old May 7, 2008 | 08:09 PM
bad boy rs's Avatar
bad boy rs
Thanks for the info peeps
I hink what ever power you run you get bored very quickly
Im just trying to weigh up th options to keep ther standarde rods or go with the hassle of fitting sum steel ones.
Ive got a satge 2+ box with quaffe diff do putting the power down isnt a problem
Old May 7, 2008 | 08:13 PM
RSricRS's Avatar
RSricRS
I have that box aswell
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
little bram
Sep 27, 2015 07:45 AM
davidfordrs
Sep 23, 2015 02:26 PM
davidfordrs
Sep 21, 2015 04:23 AM
