cosworth
Old Apr 30, 2008 | 08:13 PM
cobuck's Avatar
cobuck
Default cosworth
Hi All, Just wondering if there are anymore dirty old men out there like me?????. Cheers.
Old May 1, 2008 | 11:06 AM
krisberic's Avatar
krisberic
Default not running
Could be something to do with cps. Me mates did same and after checking all the usual it turned out to be the fuse for the lambda sensor kept blowing every time we put ignition on. It was the wires on the lambda sensor wich had melted together causing the ecu to shut off the signal from cps. Give it a try
Old May 1, 2008 | 11:09 AM
timster's Avatar
timster
Could be cps although mine started misfiring and cutting out for a split second whilst driving.
Old May 1, 2008 | 07:36 PM
stage 3 muppet's Avatar
stage 3 muppet
crank sensor i would say pal mine did exactly the same with no warning ....could also checked its gapped properly
Old May 3, 2008 | 11:00 PM
cobuck's Avatar
cobuck
Thanks all for your help. I got the car going, happy daysIt was the two big black plugs beside the coil, one of them was not making proper contact.
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
