Multi Plugs on the Inner Wing behind the headlight.....
Old Apr 30, 2008 | 07:57 PM
RS Bowk's Avatar
RS Bowk
Default Multi Plugs on the Inner Wing behind the headlight.....
Been told by a lot people to do away with these plugs. There is probably about 30 odd wires on them and have been told to hard wire them.
What have you lot done?
Any pics would be great
Cheers Mark
Old Apr 30, 2008 | 09:48 PM
mikedaf2's Avatar
mikedaf2
if you mean the engine loom plugs i have done away with mine as they where causing running issues. just solder them and heat shrink the individual wires then wrap the whole lot in insulation tape to make it look like the rest of the loom.
Old Apr 30, 2008 | 09:56 PM
RS Bowk's Avatar
RS Bowk
have u got any pics of yours all done?
also did u put the loom in the same place or re route it?
Old Apr 30, 2008 | 10:29 PM
mikedaf2's Avatar
mikedaf2
here are a couple of pics but it is difficult to see as i have hidden the wire buy the power steering bottle.
Old May 1, 2008 | 09:38 AM
RS Bowk's Avatar
RS Bowk
Thanks for that mike
Any one else done anything different?
Old May 1, 2008 | 09:44 AM
Ryan's Avatar
Ryan
thats the only thing you really can do other than replace the entire engine loom with a new aftermarket item.
Old May 1, 2008 | 10:55 AM
MATCOS's Avatar
MATCOS
I had it done on mine as it does cause issues, mine were cut out and then resoldered and heat shrunk.
Old May 1, 2008 | 03:11 PM
RS Bowk's Avatar
RS Bowk
Any pics Mat?
Old May 1, 2008 | 07:57 PM
AlexD's Avatar
AlexD
Post Miester !
When i 1st bought the escos, i had a friend come round and cut the multi plug out, we did one by one, they are colour coded, BUT.... they dont all match up, some are different colours each side of the plug.
He solderered them, then put shrink wrap, then bound the lot together.
I had a couple of running probs aswell.
It seem stupid they put the plugs right under the open bonnet vent, handy when it rains
When we pulled them apart they had wet in them .
Old May 2, 2008 | 05:17 PM
RS Bowk's Avatar
RS Bowk
Has anyone got a wiring diagram for this part of the loom.
Incase it doesnt work when ive done it all. lol which of course wont happen.
Old May 2, 2008 | 07:51 PM
MATCOS's Avatar
MATCOS
Originally Posted by RS Bowk
Any pics Mat?
No sorry, once it's done it just looks like a thick black wire, I then neatened mine up with some cable tidy stuff and tape, it actually looks quite factory
Old May 2, 2008 | 07:54 PM
Mark Shead's Avatar
Mark Shead
If you do it cut each wire until corrosion is gone this could be as far as the ecu or sensors.
Mark
Old May 2, 2008 | 10:31 PM
Cozzie Bhoy's Avatar
Cozzie Bhoy
I pulled mine apart, cleaned em up and then wrapped the connectors in Denzo tape and then insulation tape. No probs now.
Old May 3, 2008 | 09:24 AM
THE RADMAN's Avatar
THE RADMAN
denso? are you a plumber as well? lol,when i had mine i cut them out and soldered them one by one, but in the end had to fit a complete new engine loom
Old May 3, 2008 | 09:05 PM
MATCOS's Avatar
MATCOS
Mark
Mr Shead did mine
Old May 4, 2008 | 11:48 AM
Cozzie Bhoy
Sure am RADMAN, I've dug up gas pipes that were covered in that shit and they were perfect after spending years in damp earth! Great tak!!
Old May 4, 2008 | 03:02 PM
THE RADMAN's Avatar
THE RADMAN
must admit ive never thought of using it on a car no good for the concoursers lol
Old May 6, 2008 | 04:43 PM
cozzed's Avatar
cozzed
I tried cutting mine out only to find to water had crept along cables as far as bulkhead.
Ended up cutting all of the engine control wires out of the loom( rewrapping it) , then added a pectel loom instead , had no running issues since.
Old May 6, 2008 | 11:10 PM
Cozzie Bhoy
The Anoraks will hate me for it!
gambo08
Feb 4, 2016 10:49 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
deathrider666
Sep 28, 2015 06:12 PM
