Wiper problem??
Old Apr 28, 2008 | 07:20 AM
jacko996's Avatar
jacko996
Default Wiper problem??
Wipers work but dont return to the bottom position, just stay wherever you switch them off
Any ideas
Old Apr 28, 2008 | 12:04 PM
Dave Henshall's Avatar
Dave Henshall
duff wiper stalk which is also the sidelights and indicators, the sidelights switch often fails causing no dash illumination or side lights, so its possible the wiper side has failed.
Old Apr 28, 2008 | 12:38 PM
Paul_Painter's Avatar
Paul_Painter
Hello Mate
I'd suggest that it is the motor that is faulty.
Paul
jacko996's Avatar
jacko996
It was working before I took it apart
Lights and sidelight all still work though
Old Apr 28, 2008 | 02:37 PM
Kelv's Avatar
Kelv
Almost there!
ive got a spare indicator stalk which im going to fit in mine.
gladly borrow it and give it a try, see if it fix's it.
Old Apr 28, 2008 | 08:21 PM
jacko996's Avatar
jacko996
Cheers Kelv
Got someone coming round to have a look tomorrow, and will let you know if I have no joy.
Cheers for the offer mate
Old Apr 29, 2008 | 03:27 PM
hughy's Avatar
hughy
Any ideas
yes m8 you say they don't return to bottom did you hav th linkages of? i had same sort of problem wi mine cause i had th wiper motor screwed out but it was jus a case of adjusting th linkages where they are screwed on to th motor, if not that prob wiper stalk
Old Apr 29, 2008 | 06:30 PM
jacko996's Avatar
jacko996
All sorted now thanks to everyone with input
Was just a loose connection on motor in the end
Old Apr 29, 2008 | 06:46 PM
THE RADMAN's Avatar
THE RADMAN
a cheap fix, that makes a change for a cossie
Old Apr 29, 2008 | 06:51 PM
jacko996's Avatar
jacko996
Cheapest one ive had yet
DAZZER
Sep 30, 2015 08:43 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
