Stiff Clutch? Problem or Not?
Old Apr 27, 2008 | 10:17 PM
jameslee's Avatar
jameslee
Default Stiff Clutch? Problem or Not?
Hi all,
Firstly, i am new to passionford! Just got myself a nice Series 1 Escourt RS Turbo. I use to drive a Mondeo ST200 but i have sold it on (only had 36k on the clock). I hope im not being rude by making my first post needing help!
Firstly, i am not mechanically minded, very little knowledge lol.
The Clutch on my RS seems really stiff, i have to put the thing right to the floor to change gear (duh! lol), It seems to only allow for gear change when its right to the floor, where as other cars i have driven bite half way(ish) - This could be how RS's drive though right?
Whats annoying is getting the "bite" because its stiff, its obviously not smooth, therefore getting the sweet spot for first gear has "taken practice" to perfect, im just wondering if i am able to get a garage to look at it to free it up a little bit? New cable perhaps?
Dont get me wrong, i love the car to bits an always have, if this is the way it drives then thats cool, but if i can make it smoother, i would feel better all round!
Many Thanks!
James
Old Apr 27, 2008 | 11:13 PM
Red_bull's Avatar
Red_bull
is the engine tuned? Maybe your clutch is changed for a race clutch? and me car has no probs with changing gear with clutch haveway. Maybe the clutch quadrant is in bad shape. That's something you could check
Good luck with the car!
Old Apr 28, 2008 | 09:27 AM
jameslee's Avatar
jameslee
Well im not sure, luckily the previous owner kept all the invoices of work done it. Ill run through it all and check to see if i can see what clutch was last installed, and post back.
Old Apr 28, 2008 | 10:24 AM
Spax's Avatar
Spax
Might need a new cable mate, pop up my house one day this week and try mine
Old Apr 28, 2008 | 05:06 PM
Karlos G's Avatar
Karlos G
Balls Deep!
My clutch feels stiff/heavy and the biting point is lower than normal but it is uprated to a AP Racing clutch to handle the extra power i'm running, sounds like yours maybe uprated too.
Do yo know what power your are putting out? Anything over about 165bhp (approx) and will need a uprated clutch.
Old Apr 28, 2008 | 05:50 PM
grayzo's Avatar
grayzo
grayzo
could be clutch arm
Old Apr 28, 2008 | 06:08 PM
LEE-RS's Avatar
LEE-RS
Custom
best thing is have a drive of another rst see what you think
Old May 20, 2008 | 03:32 PM
jameslee's Avatar
jameslee
Hi all - update!
Spax kindly fitted a new Clutch Cable and Accel Cable!
Prior to Spax doing this there was a "rubbing" noise when the clutch pedal was pressed. It is most likly a clutch release bearing! So im told!
After the new cable, the clutch peddel is much smoother but problem is still there.
Anyhow, the car is putting out about 160BHP i belive. The clutch is uprated according to recepits
I only get problems with it when its running hot! Currently im trying to sourse a clutch, Spax is trying to find some finnis(?) for me! lol
I presume i will be ok with a standard clutch although an uprated one would be better!
Hope it aint to much work for a mechanic to do!
Old May 20, 2008 | 04:54 PM
grayzo's Avatar
grayzo
grayzo
Ap Paddle Clutch All The Way I Just Got One And Its Been Amazing Just Dont Buy A Techni Clutch
Old May 20, 2008 | 05:02 PM
tomtomrst's Avatar
tomtomrst
hi my s2 rst was exactly the same and when the car got warm i strugled to get gears.i fitted an ap racing organic clutch and a mk5 escort clutch pedal. the pedal sits a bit higher than normal but it feels loads better to drive. hope this helps
Old May 23, 2008 | 04:43 PM
jameslee's Avatar
jameslee
Default Clutch
Hi Guys,
Yeah i read about the AP paddle clutch, i seen them for sale on ebay also. Where did you guys get them from? Prices i seen is in the 200 range. Do you guys know where the best place might be to get one of these clutches?
Many Thanks
Old May 23, 2008 | 09:09 PM
jameslee's Avatar
jameslee
Hi Guys,
Found this site: https://www.burtonpower.com/product_main.aspx?home.aspx
Im looking at the 200mm (CP2000-6) - Its £212 and it says you dont need to mod the clutch pedal although i belive mine is modded anyway.
What do you guys think?
Old May 24, 2008 | 09:18 AM
nigel b's Avatar
nigel b
get a 220mm clutch and a s2 flywheel
yatta
May 21, 2016 10:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Rammer46
Sep 18, 2015 08:31 AM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
