Cosworth Ecu
Old Apr 27, 2008 | 06:16 PM
COLEYST200's Avatar
COLEYST200
Default Cosworth Ecu
HI lads iv just bort a RS500 ECU for 8 injectors is this a good up grade for my 3dr that will only be running 4 injectors and looking for 350 BHP . and is it any good chip upgrades like ante lag lornch control and so on or have i just lost some ££££££
Old Apr 27, 2008 | 06:21 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
im no expert but surely a normal l6 ecu would have been sufficient?
Old Apr 27, 2008 | 06:38 PM
COLEYST200's Avatar
COLEYST200
You might be right mate at the mo i have a L1 and i just won the RS500 ecu for £66
i just sore it and fort that seam cheap so i won it ..is it better than a L1 ???????????????
Old Apr 27, 2008 | 06:44 PM
JamesH's Avatar
JamesH
Clearly not if the chip is for 8 injectors and you're running 4 still
What stopped you from getting a L6/L8 and a suitable chip?
Old Apr 27, 2008 | 09:28 PM
COLEYST200's Avatar
COLEYST200
At the mo i have 2 ECU,S and both of them are L1 and one of them dose not work right any way
So wot is a RS500 ECU ( L1 L6 L8 ) i just dont no
And i will be having to by a chip for wot ever ecu i run so thats not on my mind at the mo ..
the car is still being bilt at the mo and when its done i will be takeing it up to MSD to have it all set up
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
James Porter
Aug 14, 2015 12:43 PM
Aug 14, 2015 07:29 AM
