actuator problems
Old Apr 26, 2008 | 02:57 PM
rst 2's Avatar
rst 2
Default actuator problems
after a long run when the cars hot its starts to cut out apparantly the actuator is failing to work due to the wires running near the turbo and getting too hot, has any body had this problem? been told best bet is to re run the wires has anyone done this and if so where did you run them?
Old Apr 26, 2008 | 04:09 PM
grayzo's Avatar
grayzo
grayzo
actuator wnt cause the car to cut out sumin else try getting the car set up fella might do the trick
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
