4x4 Sapphire Cosworth - Turbo coolant banjo
Old Apr 25, 2008 | 04:00 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default 4x4 Sapphire Cosworth - Turbo coolant banjo
I have a slow leak where the water coolant goes to the turbo (banjo connection on the side towards the head).
I seem to remember there are two copper washers on either side of the banjo, can these be replaced with dowty washers ? I have some with nitrile rubber, but not sure they will stand the turbo housing temps...
Either way, do you know what size the washers are, or, FINIS code, so I can get some before getting anything undone ?
Thanks in advance
Greg
Old Apr 25, 2008 | 11:44 PM
jon@work's Avatar
jon@work
don't use the dowty washers
the banjo thread size is 18mm
Old Apr 26, 2008 | 04:18 AM
The copper washers are cheap enough, or you can reanneal(soften) your old ones by heating to cherry red colour and dropping in OLD engine oil.
Old Apr 26, 2008 | 11:56 AM
frog's Avatar
frog
Righty-oh, just what I thought regarding the dowty washers. I've ordered a selection of new copper ones in various sizes
Thanks for the help again
Tabetha, agreed they are cheap, but following my experience with copper washers on the fuel pump and filter I try and use dowty ones whenever I can instead
Aug 14, 2015 07:29 AM
Escortdriver1
Aug 13, 2015 05:55 PM
pegaz
Aug 12, 2015 07:30 AM
yawiejon
Aug 10, 2015 08:12 PM
jdsjojo
Aug 1, 2015 08:50 PM
