4x4 Sapphire Cosworth Fuel Tank
Old Apr 25, 2008 | 03:57 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default 4x4 Sapphire Cosworth Fuel Tank
Mine is weeping, seems it's gone porous or something...
Can you get new ones, if so where ? Or, is it a case of looking for a decent second-hand one ?
Also, any tips on removal and refitting (apart from making sure tank is pretty much empty before starting , oh, and not smoking on the job ) ???
Old Apr 25, 2008 | 04:01 PM
They often rust around the outlets, the strap often break, and captive bolts seize in as well.
I know HADRIAN sell tanks to fit mk1/2 carb and injection sierra's, sapphys,estate hatch etc.
Old Apr 25, 2008 | 04:25 PM
frog's Avatar
frog
The bottom of the fuel tank is damp and there's a definite smell of petrol around the car when it's been parked anywhere for a while .
Looked up Hadrian, only seem to list a P100 fuel tank for a 1990-> sierra I would be surprised if they were the same
Old Apr 25, 2008 | 04:56 PM
rapidcossie's Avatar
rapidcossie
you can get brand new 2wd ones from motor factors so would imagine 4x4 are available too
Old Apr 25, 2008 | 11:42 PM
jon@work's Avatar
jon@work
same tank on all sierra/saff cossies
Old Apr 25, 2008 | 11:45 PM
Jasesapphy's Avatar
Jasesapphy
Actually Not
The 4x4 and 2wd tank are different
Old Apr 26, 2008 | 04:16 AM
I thought there was a difference but don't know what it is.
Hadrian list 30-35-383 Petrol Injection/Diesel Tank DOHC sal/est/hb Ł52.50
I cannot confirm of the FIVE listed if it will fit, as DOHC probably does not refer to cossie's but twinkies etc, but check ford parts dept to confirm.
Old Apr 26, 2008 | 11:43 AM
frog's Avatar
frog
Been to motor factors (motor parts direct) and they list three, one of which is wedge shaped which I believe is for the P100, and two others, chap there couldn't tell me which one would be right
Will call ford on monday
Old Apr 26, 2008 | 12:08 PM
rapidcossie
sure they are only 40 quid each...
just buy both then return the other.
Old Apr 26, 2008 | 08:47 PM
frog's Avatar
frog
There's an idea
Old Apr 27, 2008 | 01:37 AM
SS1's Avatar
SS1
make sure its got a SWIRL POT INSIDE before you buy it
Old Apr 27, 2008 | 11:43 AM
frog's Avatar
frog
Eh ???
Old Apr 27, 2008 | 02:33 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
You need the version with the small sender hole
Old Apr 27, 2008 | 08:41 PM
SS1's Avatar
SS1
Originally Posted by frog
Eh ???
some motor factor tanks dont have a swirl pot in
like mine
Old Apr 27, 2008 | 09:20 PM
frog's Avatar
frog
like mine
Ah ok, that makes sense... I think I'll ask ford first and see if the price difference is worth going to a motor factors
Old Apr 27, 2008 | 10:02 PM
SS1's Avatar
SS1
heres your answer in full matey glad to help you
all the part numbers you need too
https://passionford.com/forum/showth...tank+swirl+pot
regards avid
steerfromdarear
28
Jan 29, 2016 06:14 PM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
155lee
14
Aug 22, 2015 12:15 PM
ekjim
Aug 17, 2015 08:57 PM
taylora1409
Aug 12, 2015 12:06 PM
