RS500 intercooler - modified for GT30/35 turbo
This is a GENUINE RS500 intercooler, which has been modified.
£300 inc. post (not including highlands etc.)
- The intercooler inlet pipe has been straightened, this is useful for use with GT30 type turbo conversions.
- There are two threaded holes on the top of the inlet pipe for temp probe/water injection unions (easily blocked with blanking plugs, not included).
- There is one threaded hole on the top of the outlet pipe for a temp probe/water injection union (easily blocked with blanking plugs, not included).
- One of the top mounting brackets has been cut off (pretty simple job to weld a new one on if that was a problem)
- The other top mounting bracket is bent down (easy to bend it back)
- And finally, a hole has been tapped into the bottom of the intercooler, currently fitted with a sealing union.
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
Matt Baxter
Sep 16, 2015 08:30 PM
AndrewStrang
Sep 1, 2015 11:16 AM
