Removing carbon build up?
Old Apr 23, 2008 | 07:27 PM
cosrep's Avatar
cosrep
Default Removing carbon build up?
Whats the best way to remove carbon build up on exhaust and inlet valves when they are removed from the head?
Old Apr 23, 2008 | 09:12 PM
Bubs's Avatar
Bubs
I find the best wat to clean them up by using a drill. put the stem of the valve in the chuck (dont tighten too much or you damage the valve) put in the vice an put the trigger lock on this leaves you to use some fine emery tape of some steel wool. then relap them when your building the head back up.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
nico12
Dec 31, 2015 04:42 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Fudgey
Sep 17, 2015 01:06 PM
