Rear ARB Bushes and Fuel pipe
I`m in the process of buying s2 rst and just getting it ready for an MOT.. We have had it on ramp and it needs the following:-
The fuel pipe from pump to tank has a slight leak.. (I`m guessing this is a ford part only and is it still avl??)
Also the rear drop link bushes on ARB need replacing, is this a ford part too or will a motorfactor do them..
Any advise welcome..
Are you talking about the metal fuel pipes that run from front to back?? If so i doubt FORD will do them anymore but you could try
You can drop links from FORD about £11 each i got some recently
Oct 9, 2015 07:38 PM
RIB1122
Aug 12, 2015 08:49 PM
track.focus'd
Aug 12, 2015 05:53 PM
