escos boost
Old Apr 22, 2008 | 05:25 PM
kcosneil's Avatar
kcosneil
Default escos boost
hi im new on here my escort is running
stage 3
803's
3-bar map
bailey breather system
mongoose
group a filter
mahle pistons
pectel p8
group a head gasket
cosmetic rocker
-31 acuator
but my cars only running 19 psi boost the question is can i adjust the acuator to run more boost and will there be enough fuel.
any help would be great
Old Apr 22, 2008 | 05:29 PM
kcosneil's Avatar
kcosneil
forgot to say its got a .63 turbo housing
Old Apr 22, 2008 | 11:58 PM
reisskahn's Avatar
reisskahn
Hi welcome yeh you should hopefully be able to more boost with that spec but all depends on what chip you got in there now and i'd honestly recommend you get it checked over/set up by a tuner..
If theres no chip in or you need a new chip/remap for it i'd highly recommend Norris Motorsport based in Derby well worth it....
Hope that helps
Old Apr 23, 2008 | 09:59 AM
kcosneil's Avatar
kcosneil
its running a stage 3 chip / pectel broad by ahmed bayjoo
Old Apr 23, 2008 | 10:43 AM
reisskahn's Avatar
reisskahn
If its one of Ahmed's chip most likely you should be able to run more boost but like i said your defo better of taking it to a reputable tuner (whereabouts you from?) and get them to tweak it up for you.
In that way they'll able to see whats the max boost you'll able to run safely on your setup & chip without it detonating etc...
best of luck
Old Apr 23, 2008 | 10:55 AM
Stu @ M Developments's Avatar
PassionFords Creator
Depends totally on spec of chip and capability of fuel pump. Also check your plugs are cool enough.
Old Apr 23, 2008 | 04:46 PM
kcosneil's Avatar
kcosneil
cheers guys think im gona get it in to the tuners for proper set up
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Russ Payne
Sep 25, 2015 08:29 PM
