Escort Cosworth Koni Problem
Old Apr 22, 2008 | 05:10 PM
gaz3678's Avatar
gaz3678
Default Escort Cosworth Koni Problem
I've just replaced my knackered suspension for a koni sport kit (-30mm) and have hit a problem.
The spring cups on the front shocks are rubbing on the tyres. The cars running 18" Rondell's with 225/40 R18 tyres.
Spoken to a couple of tuners and they suggest either using a hammer to alter the the cups so they fit (not a prob as the springs are tapered so there's loads of spare meat on the cups) or to use 5mm spacers. Not too happy about using spacers as there isn't much meat for the nuts as it is.
Any idea's????????
Old Apr 22, 2008 | 07:31 PM
garrett-killer's Avatar
garrett-killer
i´ve got the same problem mate,
you need min.15mm spacers with yokohama (wide tyres)
i used the hammer
regards chris
Old Apr 22, 2008 | 08:55 PM
PewteRS's Avatar
PewteRS
I used a BIG hammer
Old Apr 22, 2008 | 09:04 PM
ECOS95's Avatar
ECOS95
Originally Posted by PewteRS
I used a BIG hammer
As above, I had to do this. It can depend on the wheel off set though. I have 8.5 x 18 et18 & they still required the spring cups modifying. I've got another set that are 8 x 18 et25 & I've had to buy spacers (Eibach) not the cheap ones from Halfords to get them to fit.
Old Apr 23, 2008 | 06:28 AM
You could use LONGER studs with the spacers ?
Old Apr 24, 2008 | 10:14 AM
garrett-killer
to much spacers on the front isnt good,
keep the ET as low as possibile
you got to much torque steer,
better lower ET - much better handling.
regards chris
Old Apr 24, 2008 | 10:34 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
This is why I supply the Mos in ET15, as ET25 causes these issues. I personally don't like spacers UNLESS they are proper hub centric ones (which Eibach do 10mm ones ).
This is what you have to do to the spring cups to clear .
Old Apr 24, 2008 | 11:03 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Thank fuck I found someone with the same problem. I gave up and fitted coilovers on the front LOL.
Old Apr 28, 2008 | 04:49 PM
gaz3678's Avatar
gaz3678
i took a big hammer to it in end, im gutted but after all the greef i enjoyed hiting the shit out of them thank for advise
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
