cam timing verniers
Old Apr 22, 2008 | 12:50 PM
lamb chops's Avatar
lamb chops
Default cam timing verniers
As some of you will know ive had issues with my power being delivered to early so want to setup my verniers properly, what would people in the know recommend for standard cam setup? Follow the standard recommendations or can any improvements be had by advancing / retarding the cams when doing this? Would be a proper setup with rocker off and timing disk etc.
Old Apr 22, 2008 | 12:51 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
For best results, set it up on a set of rollers.
Old Apr 22, 2008 | 12:57 PM
rsnissan's Avatar
rsnissan
how much has your head been skimed by?
Old Apr 22, 2008 | 01:01 PM
lamb chops's Avatar
lamb chops
yeah i had it on rollers Chip but they were reluctant to touch it...
Not sure Andy but ive got away with a tooth out on both the inlet and exhaust so must have some meat on it
Old Apr 22, 2008 | 01:09 PM
Luca's Avatar
Luca
Lukesville
Im still shocked they wouldnot touch it John, hardly a massive task for them.
Old Apr 22, 2008 | 01:18 PM
lamb chops's Avatar
lamb chops
yeah i know Luke.. never mind
Old Apr 23, 2008 | 06:34 AM
This kind of thing is one of the REASONS why rolling roads exist, if you have a set of verniers on an engine, then it is simply a matter of tweaking this way and that way, by minute amounts at a time, to get the best.
ALL engine work, tune ups etc are at the customers risk, obviously sometimes they can hit valves pistons if skimmed a lot(?), but this would be felt turning engine over on the starter anyway.
Old Apr 23, 2008 | 09:07 AM
stage 3 muppet's Avatar
stage 3 muppet
Originally Posted by tabetha
This kind of thing is one of the REASONS why rolling roads exist, obviously sometimes they can hit valves pistons if skimmed a lot(?), but this would be felt turning engine over on the starter anyway.
i sure hope you meant turning over by hand tabetha as torque from starter motor bends valves easily lol
Old Apr 23, 2008 | 09:15 AM
rsnissan's Avatar
rsnissan
If standard cams then I would only bother with Verniers (if at all really) if the head has been skimmed a bit in the past.....................and it would need to be done properly on the rollers as said
Old Apr 23, 2008 | 11:03 AM
lamb chops's Avatar
lamb chops
yeah fair point Andy, they were only on there for future profing and because im a bufty
Old Apr 23, 2008 | 11:43 AM
lamb chops's Avatar
lamb chops
RUBY123
Oct 22, 2023 12:04 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
