Some boost questions
Old Apr 20, 2008 | 08:03 PM
Super5's Avatar
Super5
Default Some boost questions
Hi, Folks
I have some questions about the boost settings on my 2wd saph!
It's fitted with a t3, 803's, rs 500 int, 3"scorpion.
What pressure can hold a t3 turbo?
Mine is peaking very short 25 psi and holds 15 psi.
Why does the boost drops so much? can that be the amal valve?
I have shortly fitted a -34 actuator and then it holds 20 psi, but would that be healty for the t3 turbo?
Cheersss
Martijn
Old Apr 20, 2008 | 08:36 PM
KSA-Cossie's Avatar
KSA-Cossie
I ran my t3 at 26 peak dropping to 21 held.
Old Apr 20, 2008 | 08:48 PM
xr_craig's Avatar
xr_craig
Should be fine mate. Boost dropping so much was probably down to a tired actuator, thats why it's not as bad now
Old Apr 20, 2008 | 08:51 PM
Jasesapphy's Avatar
Jasesapphy
you need a good -31, a -34 too much, should never really need to use one unless you need high boost i use a -31 with 27psi on a T34,
Old Apr 21, 2008 | 02:33 PM
Yura's Avatar
Yura
my T3 peaks 25psi, hold 21-22psi - and this is not the limit. I use -31 and boost controller.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
