was my car dyno'd properly ?
Old Oct 23, 2004 | 08:19 PM
mrviper's Avatar
mrviper
Default was my car dyno'd properly ?
took my car to be tested on the dyno'd but i dont think it was done properly
basicly he did the run from 2k rpm untill the power started to drop off at about 5.9k then dumped the clutch
he did a couple of turbo cars and stoped at 4.2k rpm!
shurely you need to go from tickover untill the limiter kicks in
my 2.0 fez dod 153 bhp at jamsport about 2 month ago and 137.8 on this new dyno in leicester called street racers
the dyno model is a MAHA LPS 3000 4WD jobbie aparently only 3 in the country
Old Oct 23, 2004 | 08:21 PM
Porkie's Avatar
Porkie
You had your car rolling roaded mate
This is a Dyno
Old Oct 23, 2004 | 08:22 PM
Rick's Avatar
Rick
have u a graph? u dont do it from tickover, and, if power starts to drop off, or something isnt right - he'll dump the clutch.
Old Oct 23, 2004 | 09:01 PM
Disabled Account's Avatar
Disabled Account
This is a Dyno
Porkie, some peeps refer to rolling roads as "chassis dyno's"...(as aposed to engine dyno's).
Alos the Maha is a good quality german built/designed rolling road..........quite a few in the UK
Old Oct 23, 2004 | 09:27 PM
mrviper's Avatar
mrviper
lol its not a vtec or pug s16 engine where it will rev past 7k and keep pulling like a race horse out of control
the power will drop off at the top end natualy around 6k on a std 2.0 zetec
he just stoped as soon as he got the highest power ie as soon as the power started to flake off
personaly if you want a proper print out he should do the whole range the engine is capable of ie from 1k to 7k and get the results from that
Old Oct 23, 2004 | 09:31 PM
Rhys's Avatar
Rhys
If the power started to drop of yeah he would have stop as no piont in going on. But surley he should have made it better so it pulls a lot hiugher up than that what car are we talking about?
Adam-M
22
Aug 10, 2015 10:46 AM
yawiejon
15
Aug 9, 2015 06:36 PM
