1.7 torque settings
Old Apr 16, 2008 | 09:34 PM
Frisco's Avatar
Frisco
Default 1.7 torque settings
Im looking for a list of torque settings for teh puma 1.7 engine. Anyone got one or know of a site that lists them?
Failing that does anyone know the torque setting for the cam cap bolts on said 1.7 engine
Old Apr 17, 2008 | 03:29 PM
Frisco's Avatar
Frisco
Nobody?
Someone must have autodata or the like.
Old Apr 17, 2008 | 06:24 PM
groomers's Avatar
groomers
here you go
Torque Specifications
DescriptionNmlb-ftlb-inCatalytic converter to exhaust manifold4735-Intake manifold to cylinder head1813-Intake manifold bracket to transmission3526-Catalytic converter bracket to cylinder block4735-Suspension arm to spindle carrier5238-Vibration damper to lower suspension arm8059-Battery cable to starter motor6-53Solenoid lead to starter motor118-Radiator crossmember2518-Ground lead to transmission3324-Suspension strut nut4634-Drive belt idler pulley2518-Battery box2518-Power steering pump bracket to cylinder head.2418-High-pressure line to power steering pump6548-Exhaust pipe4735-Coolant pump to cylinder block9-80Compressor - Air Conditioning2518-Upper part of oil pan to cylinder block2015-Upper part of oil pan to clutch housing4432-Lower part of oil pan to cylinder block9-80Generator4936-Wiring to generator118-Catalytic converter heat shield6-53Exhaust manifold heat shield7-62Gearshift stabiliser5541-Camshaft timing pulley (exhaust)6044-Camshaft timing pulley (intake)10577-Camshaft timing pulley blanking cap (intake)3828-Front engine mounting bracket6951-Front engine mounting bracket to cylinder block5541-Nut, rear engine mounting bracket5037-Rear engine mounting brace118-Engine roll restrictor to engine5037-Engine roll restrictor to front crossmember6951-Coolant pump belt pulley2518-Drive belt idler pulley2518-Thermostat housing to cylinder block9-80Oil pump to cylinder block9-80Oil baffle plate to cylinder block9-80Oil pick-up pipe to oil baffle plate9-80Oil pressure switch to cylinder block1511-Oil dipstick tube to cylinder head118-Oil drain plug3727-Oil filter1713-Bolt, transmission fluid check bore3526-Cylinder head bolts, stage 1.1511-Cylinder head bolts, stage 2.3022-Cylinder head bolts, stage 3.90 °90 °-Cylinder head cover to cylinder head10-89Cover plate to cylinder head cover6-53Fuel distribution pipe to cylinder head2317-Exhaust manifold studs to cylinder head1713-Intake manifold studs to cylinder head10-89Coolant distribution pipe studs10-89Exhaust manifold to cylinder head5440-Camshaft position sensor (CMP sensor) to bracket9-80Camshaft position sensor bracket9-80Spark plugs1511-Engine lifting eye to engine (rear)2015-Engine lifting eye to engine (front)5037-EI ignition coil6-53VCT solenoid valve to cylinder head9-80Camshaft bearing caps, stage 1.8-71Camshaft bearing caps, stage 2.1713-Timing belt cover9-80Bracket, right-hand front axle halfshaft centre bearing3324-Retaining bracket, right-hand front axle halfshaft1813-Coolant distribution pipe to cylinder head2015-Coolant connection to cylinder head9-80Drive belt cover6-53Timing belt guard to cylinder block9-80Timing belt tensioner3526-Timing belt tensioner adjustment bolt2015-Crankshaft position sensor (CKP sensor) bracket to cylinder block9-80Crankshaft rear oil seal carrier9-80Crankcase breather to cylinder block9-80Blanking plug for timing peg bore, crankshaft TDC2518-Crankshaft pulley/vibration damper, stage 14030-Crankshaft pulley/vibration damper, stage 290 °90 °-Big-end bearing cap to connecting rod, Stage 12115-Big-end bearing cap to connecting rod, Stage 245 °45 °-Flywheel to crankshaft8563-Clutch pressure plate to flywheel2921-
Old Apr 17, 2008 | 09:02 PM
Frisco's Avatar
Frisco
So on the cam caps thats
1- 8Nm
2- 17Nm
Thanks a million mate
steve.rst
Mar 15, 2016 08:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
JamboRS
28
Sep 14, 2015 09:02 PM
