cosworth brakes disks/pads
Old Apr 16, 2008 | 06:22 PM
SWIFTY's Avatar
SWIFTY
Default cosworth brakes disks/pads
where is the best place to get them from??? i want better ones than standard but dont want to brake the bank.
thanks
Old Apr 16, 2008 | 09:16 PM
rinus_2005's Avatar
rinus_2005
normal / sporty road use? ebc greenstuff & discs? available everywhere
Old Apr 17, 2008 | 05:16 AM
As above you could use GREENSTUFF, but may not want to!!
The current greenstuff is V7, and is crap IMO, V4 was ace, depends how you like your brakes as the cossie will easily overheat/fade greenstuff, unless a very normal spped driver.
I have greenstuff on me other halfs astra 1.4(auto)mk3 and they oiver heat all the time as they just get too hot.
On my cossie I have Yellowstuff, which works from cold perfectly, as does Redstuff Ceramic, and these would be much more suited to "spirited" driving, but still perfectly useable on a cold winters day in the snow.
I use el cheapo discs and change them every year as mine are warped by then, which ever make I use.
original
Apr 28, 2026 05:20 PM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
Red_bull
Aug 9, 2015 08:34 AM
Old ford
Jul 31, 2015 06:50 AM
