Advise required on purchasing a 1995 Ford Escort RS2000 4x4
Old Apr 16, 2008 | 07:42 AM
maxturbo's Avatar
maxturbo
Default Advise required on purchasing a 1995 Ford Escort RS2000 4x4
Hi,
I am looking for some advise on purchasing a 1995 Ford Escort RS2000 4x4. This car has 58,000 miles and is black in colour? What should i look out for, other than rust in usual areas including wheel arch areas?
How do I check if 4x4 system is working on the car?
How many of these cars was manufactured in black in 4x4?
Does anyone know vin plate for this model?
Old Apr 16, 2008 | 08:15 AM
Mark_'s Avatar
Mark_
Originally Posted by maxturbo
Hi,
all the info you want is on www.rs2000-16v.com it will tell you what the begging of the vin should be aswell
Old Apr 22, 2008 | 07:18 AM
maxturbo's Avatar
maxturbo
Thanks for that info.
How do I check if 4x4 system is working on the car? It is true that if you jack up both wheels on 1 side of the car at the same time, turn rear wheel with hand, then front wheel will turn at the same time?
matman
Sep 9, 2015 05:45 PM
dodge8283
27
Aug 19, 2015 08:42 AM
