koni shocks
Old Apr 15, 2008 | 05:24 PM
cossie0_4's Avatar
cossie0_4
Default koni shocks
i would like to know which way to adjust my rear konis on a 2wd saph they r the ones were you push a button in on the main body and then turn them they are set in the middle but would like to make it firmer but unsure on which way to turn them ther is only 3 settings any help would be much apreciated many thanks
Old Apr 15, 2008 | 05:33 PM
I am fairly sure that clockwise is to make them firmer.
Old Apr 15, 2008 | 06:40 PM
cossie0_4's Avatar
cossie0_4
can i do this by just undoing the bottom bolt or do i need to remove completely cheers for help
Old Apr 16, 2008 | 12:07 PM
Remko GT's Avatar
Remko GT
I "think" you need to fully remove them to be able to reach the top of the shocks. It might be possible adjusting them still with the topmount fitted but tbh, I haven't tried it yet.
Old Apr 16, 2008 | 04:00 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
no mate, dont remove the whole shock. just support the trailing arm with a jack and undo the bottom. once thats done, pull the dirt cover down and you should be able to get to the button.
Just push the button in and turn the shock to adjust. cant remember which way though.
Old Apr 16, 2008 | 10:12 PM
cossie0_4's Avatar
cossie0_4
many thanks all
Nov 1, 2015 06:53 PM
Rod-Tarry
75
Oct 13, 2015 04:44 PM
SMILER258
Sep 28, 2015 09:04 AM
L1AM_RS
Sep 23, 2015 03:27 PM
