pistons
i have boght some pistons advertised as c20let ones and when they have arrived they are mahle ones from an xe engine. just wondering what pistons people have used, maybe some 86mm ones made for another engine? any comments would be much appreciated. cheers, ben
JE pistons from the usa and only about £250 to your door with rings and pins
Look on the xe pistons fopr a number. usually under the crown. If it containes a letter 'P' then they are forged pistons. In early pre 1990 xe's they used forged pistons and forged cranks. They later used cast.
yeah they are the forged ones and in proper good condition but the CR will be too high and im not using a compression plate etc. just wondering if any other 86mm pistons from other turbo cars had been used before
Bodybuilding
From: Cannot be identified by the information given.
In what engine ?
XE ones will give a cr of 7:4.1 in a zvh and 8:1 in a zetec
and good for 400 bhp if they are the early forged type
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
