best cam for erst?
Old Oct 23, 2004 | 10:56 AM
big_wig_074's Avatar
big_wig_074
Default best cam for erst?
piper or kent?obviously for power,wanna go sodding fast! can i get my std cam reground?any good?cheers all!
Old Oct 23, 2004 | 11:40 AM
james_birch's Avatar
james_birch
here wo go!...
right as ive just brought a cam ive heard a few things! ....
kent has some issues at mo!...so quality wise go piper! piper t2 will bring the power up the rev range but will kick in later! piper 285 t,is a more toruqey cam!
kent cvh34 is ment to be the bollox really good profile(if its a good'un) kent cvh 35,36,37 are ment to be high reving cams!.....what other mods you got?
theres also another cam make you might not have heard of
Newman cam's they make a cam for the rst thats ment to go ballistic at 4.5k comes with solid lifters ,and ive heard is ment to rev to 7.5k!!
and the fourth option is give Karl norris a bell as he can make u a full cam kit for a real good price and only heard good things about them! www.norrismotorsport.co.uk or he is about on here a bit you might be able to get hold of him with pm or email!
Old Oct 23, 2004 | 11:46 AM
big_wig_074
cool,cheers,theres a fair amount of torque low down just gets a bit crap from 5000rpm onwards,t2 sounds good then. cheers
Old Oct 23, 2004 | 11:57 AM
james_birch
what turbo you running? try putting a .48houseing on it that will make it breath better later on! and what intercooler you got as it may be getting hot in fith gear at 5k so ecu retards ignition!
Old Oct 23, 2004 | 01:13 PM
big_wig_074
right,the spec WILL be(as its just been bought by me and i got these bits coming) std turbo(no smoke)-31,pace cooler,stainless exhaust(unknown make,no centre section looks at least 3" straight thru)bayjoo unlimited boost ecu,bleed valve(so about 20 odd psi!!! i KNOW it may be silly but so far all this is only costing me 100 quid!) a pipercross induction kit,grp a coil(from my old cossie),champion c59cs(again from cossie),and ive rigged up a intercooler water spray(deodorant cap makes well nice spray pattern!) so thats it at the mo!havent got the pace cooler or -31 on it yet but the rest is there.think the actuator is weak also which could mean its not too hot at high rpm,its peaking at about 15 psi at the mo if i wind the bleed valve a long way! but usually 10 ish psi(dont have time to look!)
Old Oct 23, 2004 | 01:22 PM
T28 RST's Avatar
T28 RST
Ok then
[quote="james_birch"]here wo go!...
quote]
New man cams are shit hot for the RS Turbos, you can really feel the cam coming in about 4000 odd rpm and yes it does rev to silly rpm
Old Oct 23, 2004 | 01:26 PM
RSeb's Avatar
RSeb
piper piper piper!!!!
did i mention i have an unused 285t2 for sale £100
Old Oct 23, 2004 | 01:33 PM
james_birch
lmfao!
and as for running 20psi through ya pace.i do hope you got a good water spray!...but most importantly get an act gauge!
spec sounds good!
also go down an A road and full load it in 5th and see what ya boost gauge saying!...but make sure you get a r/r set up once everything on to make sure fueling and everything is good!
Old Oct 23, 2004 | 03:49 PM
JamboRS's Avatar
JamboRS
focus rs 1672
recommend newman cams got one in mine better than kent and piper
Old Oct 23, 2004 | 04:25 PM
turbo.jon's Avatar
turbo.jon
Had kent cvh35 in mine before went bang bit slow pulling away power kicks in late then revs pretty high(god i miss this )
Old Oct 23, 2004 | 06:26 PM
T28 RST's Avatar
T28 RST
Ok then
http://www.newman-cams.com/home.html
Old Oct 24, 2004 | 12:26 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
What about a PE cam.....heard these are good too!?
Old Oct 24, 2004 | 12:32 PM
KSA-Cossie's Avatar
KSA-Cossie
sx 428t is a good cam.
Old Oct 24, 2004 | 12:45 PM
big_wig_074
just secured a 285t2 piper item!should be good me thinks!
Old Oct 24, 2004 | 12:46 PM
james_birch
think they stopped making them didnt they?
they were on the same sort of profile as the piper 285t...more torqey based!
Old Oct 24, 2004 | 05:51 PM
vroooom ptssssh
It Wasnt Me!
no idea James, i jus mind it being a good cam! hope they still make em i'd like one
Old Oct 25, 2004 | 11:08 AM
sm's Avatar
sm
yep p.e no longer make thier cams and all there erst head work is now done by vulcan engineering
Old Oct 25, 2004 | 12:18 PM
vroooom ptssssh
It Wasnt Me!
Old Oct 26, 2004 | 09:46 PM
mitchrs's Avatar
mitchrs
can somebody please tell me more about these newman cams?? how much r they?
Old Oct 27, 2004 | 04:01 PM
JamboRS's Avatar
JamboRS
focus rs 1672
i got my cam thru AVA in glasgow
think the cam is just the same price as a piper or kent but you need solid lifters and double valve springs
top piece of equipment m8
try calling AVA on 01418485257
Old Oct 27, 2004 | 06:19 PM
mitchrs's Avatar
mitchrs
thanks alot geezer!! will give em a buzz first thing tommorro morning!!
Old Nov 11, 2004 | 02:22 PM
sf's Avatar
sf
did you get your newman cam, ive one in mine, recomend them
Old Nov 11, 2004 | 02:58 PM
james_birch
get my cam fitted tomorrow! piper 285T! cant wait! then after that its a bigger intercooler!
but first body and interiour mods!!
Old Nov 13, 2004 | 07:29 PM
odn198's Avatar
odn198
go for a piper m8
Old Nov 15, 2004 | 04:13 PM
©hatter Box's Avatar
©hatter Box
its a kent 34 under powers name
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
