TCA to hub
Old Apr 13, 2008 | 01:38 PM
cameron2's Avatar
cameron2
Angry TCA to hub
Whats the best way of putting the 4x4 saff back together? I cant get the tca pinch bolt in to the hub.
Old Apr 13, 2008 | 06:57 PM
If the ball pivot of the TCA has psuhed too far up into the hubn the bolt won't go in, so just jack up slowly as you look through the hole to see when it is in alignment, then tap the bolt in.
Drown it in coppaslip first though as rain gets in here and jams the bloody things in!!
Old Apr 13, 2008 | 07:19 PM
cameron2's Avatar
cameron2
I cant get the hub anywhere near the the tca! Ive got the driveshaft located, the strut located, the arb through the tca but i cat marry the tca to the hub, its about 2 inches off!
Old Apr 14, 2008 | 05:54 AM
Do you mean as in it needs to go inwards towards the car 2" ?
If so look at the driveshaft as that is pushing it out, maybe a joint has popped out inside the gaiter ?
Old Apr 14, 2008 | 06:56 AM
dojj's Avatar
dojj
Resident Wrestling Legend
if everything is sorted and all you need to do is pop the ball joint thoguh to the hub then the first thing you need to do is as tab says and make sure the shaft has slotted home fully
then, assuming you were working on the drivers side, you would turn the steering wheel full lock to the right (clockwise) so you have less of a distance to go to pop the ball joint through, and then on the other side spinn it the other way
it'll all make sense once you've done it
you also need to make sure that the ball joint is poking straight upwards as they can be a bugger to get aligned properly, you may get it into the hole but then you won't be able to get it into the hub all the way as it'll get jammed up
i hope you are using a scafold bar to drop the tca down enough to pop the ball joint on as well as otherwise you'll need a ratchet strap to pull the struts iin far enough in order to push the bolt through the inner tca hole
Sierrasideways
Oct 8, 2015 06:37 PM
fordrallycar
Sep 30, 2015 07:57 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Mark V8
Sep 13, 2015 09:34 AM
jc1989rs
Sep 5, 2015 08:09 PM
