ive got both forsale brand new pm if your interested,je forged pistons and eagle steel rods
hi mate, why are you not using them ????. any idea what compression ratio these will be fitted to a zvh ????. are they 2.0ltr or 2.1ltr pistons and rods ????.
dave
if they are the same pistons as mine je 185915 then on a zvh if i remember 8:5:1 they are meant for the black top engine but can be used in the sliver top which i am currently running.they are 85.007 mm bore.
dave
85 mm bore mate,these would work better for a cvh in my opinion,with the cvh head 55cc,thats not skimmed,would work out to be around 7.9-1....8.0-1,ive gone down another route cos these were9.01 with a zetec head and i want to go lower
hello mate how much u lookin for them then mate if u wanna give me a txt 07886 504 331
or just say on here
im looking for my cash back mate £500.00,i had to pay import tax on these,plus postage and will only post to uk speaciaal delivery which is around 25 quid cheers
sean
Are you running a decompression plate still?
I have these Rod & Pistions a ferriday de-cat plate on a zvh lump.
Im temped to remove the plate and run 8.5.1 if correct? and lower boost but a better turbo GT28 or GT30.
Jim
no m8 i'm running one of sitech racing zetec head gaskets i use to run a de-comp plate with a felpro but they spat there dummy out with 32psi plus nitrous.. i dont think ferriday engineering will be able to machine the chambers enough.. unless the head is standard i had no chance with my head..
