Gearbox oil
Old Apr 11, 2008 | 12:24 PM
kellyjones's Avatar
kellyjones
Default Gearbox oil
Hello
How much oil does the gearbox take, and what type?
Old Apr 11, 2008 | 02:02 PM
SteveB's Avatar
SteveB
2.6L (listed), changed mine last week and took just over 2L, oil to use is ATF.
Steve
Old Apr 11, 2008 | 11:52 PM
captiva's Avatar
captiva
Steve
What car are you talking about? I wanted to know which oil to use in a MT75
Old Apr 12, 2008 | 04:03 PM
Jimboxr4x4's Avatar
Jimboxr4x4
I'm sure MT75 box takes FMT. Its the transfer box that is ATF but it is over a year since I last changed mine so don't take it as gospel.
Old Apr 21, 2008 | 03:57 PM
SteveB's Avatar
SteveB
Sorry 2wd Saff/3dr
Old Apr 22, 2008 | 09:26 AM
Remko GT's Avatar
Remko GT
MT75 takes Dex III ATF.
Don't know about B&W T5
Old Apr 22, 2008 | 12:26 PM
captiva's Avatar
captiva
Do you know what goes in the rear axle as it has a limited slip diff and I don't want to kill that
Old Apr 23, 2008 | 12:17 PM
TOM33's Avatar
TOM33
MT75 Gear box only uses mt75 oil transmission oil sililar to auto transmission oil 1.2 ltrs ( ATF FOR 2WD Gearbox and 4x4 transfer box use only)
Diff use 75/90 semi or full synthetic 1 ltrs
Old Apr 24, 2008 | 06:32 AM
Note diff MUST, use LSD oil, not just general oil.
A T5 box is normally used with ATF, ATF then attacks the pads on the selector forks ends as these are made from compressed paper/card, GEAR OIL doesn't do this and is why I use it, a 70 weight.
Old Apr 24, 2008 | 06:14 PM
broos3's Avatar
broos3
From: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
I thought the LSD in the sierra was a sealed unit, therefore you dont need a specail lsd oil?? The gear oil in the diff wont come into contact with the LSD unit itself.
I also thought that ford put ATF in the T% box from the factory? So you use a 70 weight gear oil in you T5 box tabetha?
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Adam Graham
Sep 6, 2015 06:04 AM
