advice on cometic head gaskets,
i need a new head gasket for my coz, i was going to just put another grp a one on but ive seen some
cometic reuseable wrc type multilayer foam /steel headgaskets,
now , i can get these in 1.42 mm compressed thickness which apparently will lower my c/r or i can get one in standard thickness, i have a escoz 200 block in my car witha 4wd head and am going greys/t34 etc, is the 1.42mm thick one a good gasket to get and what c/r will it give, i have heard a few have had a prob with cometic but dont know if thats early ones or are they all dodgy?
cheers
carl
cheers
carl
i wouldnt use em mate, as you know i used to swear by em but after my last engine build i had one go faulty and take the block and head with it
go WRC or even good old gpA.
Sean.
Sean.
Damo V by installing them incorrectly
Its all about lining therings up..ideally they need to be installed with engine out of car!...They later ones are apparently fixed rings???Not sure though as i aint seen one yet..i run the older one obviously installed correctly
Strut brace go for a cometic .57 this should lower the comp by .9
I have one 'in stock' for when I build my replacement engine, how do I know if I have the faulty design/old one or the newer one.
Phil, surely if you were to use long studs and a cometic it would stay put as you torque the head down? What makes fitting it out of the car so different to when it's in the car.
(I can't believe I'm asking Phil for tuning advice
Now i used std head studs using a coppers ring gasket (seperate fire rings) fitted INCAR twice and both failed!!!!!!..IF i'd gone with DIY it wouldnt of happened as i would have used ARP's BUT i foolishly listed to someone else
Originally Posted by b19bal
frog if ya talking about switchs one its the newer design as he was gonna buy a wrc one till he got told about the newer version and he bought that instead
Originally Posted by Ima Racing 700
Frog do many DIYers use the locaters then!!!!...I never did when doin the Grp A's
I've only ever done one h/g on a cossie and used that... Seems to make sense to me as you are about to drop 20kg's worth of head on a cylinder block, usually holding it at arm's length. What chance does the h/g have of staying in place otherwise
frog were all friends on here and scot would have told ya if it was the old type
I am in no way suggesting he would have waylaid us... and wouldn't hold it against him if it was the old one (as long as he didn't know otherwise)
ooohh my god..........im caking it now...thats the same head gaskets thats on mine n i got it off paul down pj 2.............scariest thing is my car never ran right since it went on...ran hot all the time.........
tried all sorts 12 sort it but the temp never moved...its on gettin stripped down at the min 2 put a new head gasket on just hope when the head comes off it hasnt done more damged than expected or ill b gettin in touch with paul frm pj as no one told me they were dodgy
Good luck m8, fingers crossed for ya.
