Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
MK 1 Escort coilover spring rates
Old Apr 10, 2008 | 11:13 AM
jim jones's Avatar
jim jones
Default MK 1 Escort coilover spring rates
I'm looking for some advice on what spring rates for my car.
It's a mk 1 Escort and I'm fitting coilovers to it but not sure what spring rates to use, it will be mainly a road car with some track use. It's got a cosworth engine in if that makes any differance. Any help would be usefull
Old Apr 10, 2008 | 12:10 PM
cheftony1's Avatar
cheftony1
might want to try over on this site Jim
www.rallyesportescorts.co.uk
best of luck.
Old Apr 10, 2008 | 12:12 PM
boXXer's Avatar
boXXer
GASH!
i would say 180lbs mate.
Old Apr 10, 2008 | 04:05 PM
javars's Avatar
javars
RWD Rules
its been 6years since mine was on the road but i was running 300lb on the front and 220lb on the rear.but this does put some load on the shell, so unless you have a good fitting roll cage you will start to get stress fractures in the roof pillars.
Old Apr 10, 2008 | 04:09 PM
NUTS RuS's Avatar
NUTS RuS
What size diameter ??
Its impossible to quote rates without knowing some basic info
Old Apr 10, 2008 | 04:30 PM
javars's Avatar
javars
RWD Rules
2.25 on mine but nuts is correct lots of things to consider ive got compresion struts on the front and no anti-roll bar,four link on rear with watts linkage
Old Apr 11, 2008 | 11:15 AM
jim jones's Avatar
jim jones
They are 2.25 diameter the back is four linked with a watts axle, front has both ARB and comp struts. The car is not caged at the moment but will be at some point with a full weld in group 4 type.
Old Apr 11, 2008 | 05:21 PM
javars's Avatar
javars
RWD Rules
if your running a front roll bar i would go a little softer than the 300lb im running but get the cage in before you push it too much
Old Apr 11, 2008 | 09:05 PM
s-line's Avatar
s-line
Talking spring rates
i,m running 280 on the front and 200 on the rears, front end has adj tca,s and comp struts, rear end has been 6 linked with narrow atlas and also the cage was a s,d bolt in type now welded into place with the rear bars replaced with longer ones reaching out to the rear turrets, then cross linked for extra stiffness, as youre mine is also a mk1 with cozy and for fast road and track use!!
Old Apr 15, 2008 | 11:15 AM
jim jones's Avatar
jim jones
Smile
thank's for the advice
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
saph in dorset
Aug 14, 2015 10:10 AM
