Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
Parts for light restoration of a 3 door Cosworth
Old Apr 10, 2008 | 09:15 AM
infinicar's Avatar
infinicar
Default Parts for light restoration of a 3 door Cosworth
Hi,
Just purchased (last night) an original 1 owner from new 3dr Cosworth in white - it needs some light restoration work which Im going to carry out over the next month or so.
Ive made no enquiries anywhere yet, this is my first port of call.
Im in need of the following:
- Set of wheels (pref refurbished correctly) - or recommendation of a place where I can get the ones on the car refurbished correctly.
- Windscreen - are these readily available still?
- Foglights (pair) - the silver inside both has started to flake.
- Front bumper rubber trim at the bottom - this has been torn off and requires replacement. Just want a standard one not a 500 one.
- Parcel Shelf (not broken!)
- Rear door cards (without speaker holes cut in)
- Original overmats
- Brake Calipers (rears have got sticky)
- Been stood for 8 years and Im fairly sure the fuel pump is seized on it as there is no noise when the ignition is turned on. So maybe a fuel pump.
Thats a premlinary list. Any advice appreciated. PM me with anything.
Thanks Paul
Old Apr 10, 2008 | 02:13 PM
For the wheel refurb you want lepsons in kent 01634 580582,
and the rear door cards pm RONNIE AMIS on here as he has some
hope that helps
Old Apr 10, 2008 | 05:32 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Talk to thrush on here for the windscreen mate, he works for autoglass, in the london area, are you infinicar from bracknell?
COSWORLD
Aug 14, 2015 07:40 AM
Aug 14, 2015 07:29 AM
c14rks
Aug 11, 2015 05:17 PM
Old ford
Jul 31, 2015 06:50 AM
