90 spec efi escort spark problem
Old Apr 8, 2008 | 10:29 PM
Toe Knee's Avatar
Toe Knee
Default 90 spec efi escort spark problem
right basically converted the gfs mfi escort to efi, had a big prob sorting the fueling which i found out eventually was some1 had cut a main earth off the ecu to the batt! But now for some reason i'm not getting a spark! Remember it sparking originally when i fitted the loom and engine althou it was months ago now. So basically any1 got any ideas as to what could stop an efi escort sparking?! Cheers for any help
Old Apr 9, 2008 | 06:39 PM
Mr.T's Avatar
Mr.T
CPS sensor EDIS module something like that. Check the wires.
Old Apr 12, 2008 | 02:21 PM
fonfe's Avatar
fonfe
check that the EDIs moduel conectors arent corroded as that happened to mine once
Old Apr 12, 2008 | 02:49 PM
Toe Knee's Avatar
Toe Knee
The crank sensor is fine tried a couple of them and a fwe edis modules with no joy, now worked out that the pump primes for the first few seconds when u turn the ignition on as it should as theres fuel getting to the rail but when u crank it no fuel comes in ie pump isnt working and no spark as i said!!
Will check the edis connectors but had a look at them before and it seemed ok!!
Old Apr 18, 2008 | 09:03 PM
Toe Knee's Avatar
Toe Knee
bttt for an easy life! Lol
Old Apr 19, 2008 | 06:04 AM
Mr.T's Avatar
Mr.T
What about the DIS itself. Is that working good?
Old May 1, 2008 | 08:17 PM
Toe Knee's Avatar
Toe Knee
dis? Everythin on the engine was running fine in the 2i so should be fine. Only other thing i can think would/are any of the sensors different on a 2i efi and a 3i efi.?
Old May 2, 2008 | 08:25 AM
JesseT's Avatar
JesseT
Check that the EDIS is getting +12V when the ignition is turned on AND when you are cranking.
Old May 8, 2008 | 06:40 PM
Toe Knee's Avatar
Toe Knee
well its getting enough volts with ign on will need 2 check when cranking later. Realised the gearbox should have had a speed sensor connected so took that off the 2i but still no joy. Any other ideas?!
Old May 12, 2008 | 06:10 PM
packs's Avatar
packs
i have the same problem as you!!! i have tried 2 map sensors, 2 ecus, 2 edis modules and different crank sensors.
Old May 15, 2008 | 07:07 AM
packs's Avatar
packs
anyone? realy need help with this one
Old May 15, 2008 | 09:05 PM
boothy's Avatar
boothy
try the dizzy could be that had same prob with mine,its mfi but i took off inlet 2 paint it,put all back 2gether and wouldnt spark ,traced it to that,my mate lent on it and started after that it was a bare wire inside hope this helps
Old May 16, 2008 | 07:49 PM
Toe Knee's Avatar
Toe Knee
Shouldnt really affect the coil pack thou as it was working mint before i took the engine out of my 2i althou wont rule it out, but its not just the spark its also not running the fuel pump when u crank it althou it does prime it when the ignitions turned on!!
Looking at a mates rsturbo tomorrow that had an fez turbo efi engine fitted into it but also had the turbo loom spliced into the mfi turbo loom which works fine so fingers crossed we can work it out from that!!
Vincereese
Jun 1, 2023 09:14 AM
Dahl88
Aug 22, 2015 08:16 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Zoggon
Aug 10, 2015 10:39 AM
