i'm after a picture of an air con'd cosworth engine
Hello all,
I'm after a bit of help i'm building transit cosworth using a sierra YB engine! the donor van was a DOHC and had Air con so as most of the works done we'd like to fit a compresser to the YB and run it with air con!
I know you can get air con on the escorts but ive never seen one close up! basically what i'm after is a picture of and engine with it fitted - preferably out of the car! so i can see where the compresser and brackets are situated so i dont put anything in the way of it all
Cheers Luke
Cheers Luke
not got a pic with the compressor on the block but if you look at the pic below, the compressor bracket bolts on at the front of the engine just above the sump, i'll see if i can get a pic later of it in the car.
PassionFords Creator
Heres one with the bracket in place but no compressor...
And heres an aircon ESCOS engine bay.
Hope these pictures help.
thanks guys
the one with the bracket on is very usefull!
i intended to do away with the oil filter extention and have the oil filter mounted directly to the oil cooler - do you think the air con compresser would still fit ok ?
Luke
Luke
ah yes the cyco van
one of my all time favorites - not seen it with that plate on before tho
what BHP did you get it too ? ive seen some video's of it and it goes well enough lol
and have you seen any tranny mk6 cossys? i was hoping this is gonna be the 1st i dont know of any allready built!
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
