What Fuel hose for in-car?
Old Apr 8, 2008 | 08:14 PM
jacko996's Avatar
jacko996
Default What Fuel hose for in-car?
What is the best braided fuel hose to run in-car?
I have heard that some cheaper brands allow fuel fumes through?
teflon inner I here is the way to go, also heard of CPE Inner but not sure what that is??
Any help appreciated
Dave
Old Apr 8, 2008 | 08:48 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Mine are PTFE lined and have no problems with fumes in the car
Old Apr 8, 2008 | 08:53 PM
M K's Avatar
M K
go for the goodridge 811 series hose, or another ption is the pro gold range or startlite hose available from think automotive,
pro gold is available in nomex covered too
Old Apr 8, 2008 | 09:09 PM
gus's Avatar
gus
811 series in mine
Old Apr 9, 2008 | 06:38 AM
jacko996's Avatar
jacko996
Goodridge 811 sounds popular,
Does'nt the pro gold from Think need to use there own fittings?
Also who is the most reasonable supplier
Old Apr 9, 2008 | 08:00 AM
jacko996's Avatar
jacko996
With Goodridge 811, do you have to use their special fittings or can you use the Aeroquip fittings?
Old Apr 9, 2008 | 01:44 PM
jacko996's Avatar
jacko996
Any info would be great
Old Apr 9, 2008 | 03:06 PM
gus's Avatar
gus
yes you can only use the fittings designed for the 811 hose
Old Apr 9, 2008 | 04:06 PM
JonnyBravo's Avatar
JonnyBravo
I used this lined hose for fuel incar :
Which used the fittings with olives on the right side of this picture :
This hose for anywhere else or oil lines, this uses the normal fittings :
Old Apr 9, 2008 | 05:04 PM
jacko996's Avatar
jacko996
Looks good Jonny Were the fuel ones from Think Auto.
Got a quote on Earls today which wasnt to bad.
Anyone delt with them before?
Old Apr 9, 2008 | 05:10 PM
JonnyBravo's Avatar
JonnyBravo
I use think for everything, the pro gold fittings were given to me though and I was later informed that they were VERY expensive so I've used a alloy fitting which is black and has a blue nut on it that Think supplied me.
Just speak to them and tell them what your after and they will be able to help you out.
The lined hose isn't Earls or Aeroquip, its a hydraulic style hose they do and its MUCH cheaper than the branded stuff, no idea on what it was called but they told introduced me to it.
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Russ Payne
Sep 25, 2015 08:29 PM
