Its running!!!
Old Apr 8, 2008 | 06:31 PM
RWD Pete's Avatar
RWD Pete
Default Its running!!!
Managed to find a bit of spare time to carry on with my rebuild on the rwd saff.
Fired it up for 10 mins or so to bed cams in sounded very very healthy
Spec is as follows;
YBP Late escos engine
.5 over size cosworth racing low comp pistons.
ARP con rod bolts
STD size crank
Lightly skimmed head and block
Fully balanced bottom end
Ported and polished head
ISKY valve springs
BD14 inlet
STD exhaust cam
Cometic head set
STD headbolts
Sweedish inlet
2WD exhaust manifold
Manifolds matched
Kent verniers
GRP a coil
All new sensors
TT T38 turbo
RS500 cooler (pace)
APEXI boost controller
Gonna run in on std injectors/chip.
Then its gonna be 82 lb siemens injectors
044 pump
live remap
Hoping for 450 bhp
Nice feeling when they fire up
Old Apr 8, 2008 | 08:07 PM
costina's Avatar
costina
Live long and prosper!!
Well done Pete 1500 miles on mineral and off for a mapping session
Paul
Old Apr 8, 2008 | 08:08 PM
rapidcossie's Avatar
rapidcossie
Get some pics up!
Old Apr 8, 2008 | 08:40 PM
rst in breaking's Avatar
rst in breaking
im hoping i feel that nice feeling soon lol, glad its all up and running and hope you see good figures, well done mate
Old Apr 8, 2008 | 10:21 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Hope that turbo is ok
Steve.
Old Apr 9, 2008 | 12:24 AM
Lowson's Avatar
Lowson
Sounds good mate
I bet it did feel ace
Old Apr 9, 2008 | 06:37 AM
RWD Pete's Avatar
RWD Pete
Paul
Now then paul dont know about the full 1500 but she'll be getting a good bedding in.
Sounded sweet as a nut
Old Apr 9, 2008 | 06:38 AM
RWD Pete's Avatar
RWD Pete
Get some pics up!
Looks like a right nail under the bay, but thats the idea this year. Keep it looking rough whilst i sort all the oily bits. Just to suprise the sniggering m3 driver
Old Apr 9, 2008 | 06:40 AM
RWD Pete's Avatar
RWD Pete
Steve.
Now then steve hows tricks?
Turbo is sound mate gonna make good use of it
Old Apr 9, 2008 | 07:34 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
We are all ok except having colds
Thinking of doing another project now, wished i hadn't sold the turbo
Steve.
Old Apr 9, 2008 | 12:44 PM
RWD Pete's Avatar
RWD Pete
Steve.
Get a t4 mate
Juststarting with cold myself
You gonna be going to santa pod at some point this year??
Bloody car wont tick over
Old Apr 9, 2008 | 03:43 PM
RWD Pete's Avatar
RWD Pete
maiden voyage completed
tickovers shite, misses when held at 3000 rpm but engine sounds healthy and it has great oil pressure.
Could do with it a bit smoother for running in period before mapping sesh.
Old Apr 9, 2008 | 11:33 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Will be going to Central Day on the 20th
Any idea what the idle problem is ????
Steve.
Old Apr 10, 2008 | 07:03 AM
RWD Pete's Avatar
RWD Pete
No ides mate i have double checked timing and sensor gaps. Sounds sweet for about ten seconds then it looses its idle, gonna phone stu today see if he can send me a pre live map chip to go with the new spec. The car is on standard yellows and stg 1 chip.
Old Apr 10, 2008 | 08:26 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
That is the best thing you can do anyway as the chip you are running will be miles out for your engine now.
Steve.
Old Apr 10, 2008 | 05:22 PM
RWD Pete's Avatar
RWD Pete
Sorted idle, just needed richening up a tad
Ordrering injectors from usa and i have had a change of mind on the inlet, im gonna port my standard one on the restrictive throat and use a 10mm spacer.
Old Apr 10, 2008 | 05:44 PM
costina's Avatar
costina
which one do you have atm Pete?
Paul
Old Apr 10, 2008 | 06:43 PM
baba's Avatar
baba
10mins?id say that was it run in lol.i gave my cossie about 8 mile.....
Old Apr 10, 2008 | 07:45 PM
RWD Pete's Avatar
RWD Pete
Paul
Early one paul thought it may be easier to port as it splits?
Old Apr 10, 2008 | 07:46 PM
RWD Pete's Avatar
RWD Pete
Only done .8 mile but its seen a tad of boost. Read a good piece from garage 19 in regards to running in.
Short and sharp
Old Apr 12, 2008 | 06:01 PM
costina's Avatar
costina
To gain the most you need either a 4x4 plenum(better than 2wd) or better still a small turbo escos one they will flow upto 500 bhp
short and sharp new one on me
Paul
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
