sapphire sunroof leaking
Old Apr 8, 2008 | 04:15 PM
sideways saff's Avatar
sideways saff
Default sapphire sunroof leaking
anyone aware of any possible problems why i would have water coming thru my interior light/sunroof ?? i think the drain holes are clear as i have managed to get a piece of wire a long way down but it did stop after about 2ft...where would the drain holes lead to ???
cheers Matt
Old Apr 8, 2008 | 04:24 PM
Paul_RS's Avatar
Paul_RS
Drain holes come out in the sill mate, try puring water down the drains and see if it comes out the bottom.
Old Apr 8, 2008 | 05:18 PM
iansoutham's Avatar
iansoutham
OCD Victim
There are 4 drain tubes on the Saff. The front ones are normally okay, so I would go to the boot and behind each trim panel is a drainage point which runs through the air vent on the pre 1991 models and into a collector on the post 1991 models.
Chances are this is crapped up where it leaves the car in the boot. Water then backs up the pipe and collects in the sunroof aperture, draining into the interior light when the level gets high enough.
Be thankful it is blocked, I know many people who have had the drains come loose and pour water into the boot when it rains.
Old Apr 8, 2008 | 05:36 PM
sideways saff
perfect cheers............i'll go out with bucket in the moring and see how it goes
Old Apr 9, 2008 | 06:23 AM
Pop into your local cheapy shop and buy some CURTAIN ROD, the flexible sort, as this makes an ace push through if any are blocked, I use the stuff also to put wires etc through panels.
DON'T push too hard or the pipe could be pushed off the drain hole in the roof.
Old Apr 9, 2008 | 08:04 AM
TurboShed's Avatar
TurboShed
Cossiemodo
I use a towel draped like a tent over the gearstick and handbrake area, works a treat.
Old Apr 9, 2008 | 11:30 AM
TurboShed's Avatar
TurboShed
Cossiemodo
OMG this is taking the piss. Go out at lunchtime today, remove towel from over handbrake etc. Then realise the roof is all wet, the seatbelt wet, the water has run down the side beam next to the driver seat, into the seatbelt enclosure, FFS!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Fil
Sep 30, 2015 12:08 PM
stevecfrst1
Sep 30, 2015 05:18 AM
