Rubber Fuel Hose
Old Apr 8, 2008 | 09:31 AM
Ryan's Avatar
Ryan
Default Rubber Fuel Hose
Im after some rubber fuel hose, does it have to be fibre reinforced? as i need the hose to be as flexible as possilbe, but have a feeling if its fibre re-inforced it wont be suitable.
Any ideas?
Needs be around.
12-15mm External diameter with an internal around or above 6mm.
Old Apr 8, 2008 | 09:53 AM
bud-weis's Avatar
bud-weis
Football Cwazy
Fairly sure fuel hose needs to have the fibres..
i usually buy it in meter lengths from my local motor factors, it's pretty flexible....can get it in 6 or 8mm ID from memory, the external diameter would be around 10-12mm.
Old Apr 8, 2008 | 10:02 AM
foreigneRS's Avatar
foreigneRS
Testing the future
just make sure that it is suitable for high pressure fuel injection systems as some is only suitable for low pressure return or low pressure feed to pumps and carbs
Old Apr 8, 2008 | 01:53 PM
Ryan's Avatar
Ryan
ok
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
hopper350
Sep 4, 2015 12:53 AM
