ECU chipped?
Old Apr 7, 2008 | 06:23 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default ECU chipped?
my ecu has a red, blue and white sticker on it i think does this mean it is chipped not sure has car is running 200 brake
Old Apr 7, 2008 | 06:54 PM
flashpoint's Avatar
flashpoint
Red, Blue, white = S1 ecu with no knock sensing. you can not tel if it is chipped or not from the markings on the cover, you would have to take it apart and inspect the main chip..
cheers
Steve
Old Apr 7, 2008 | 08:04 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If you know for 100% the car is running 200bhp then yes it's chipped, unless magicaly you've acheived this without increasing the boost beyond about 8psi!!
Old Apr 7, 2008 | 08:20 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
10psi.
Old Apr 7, 2008 | 08:58 PM
denbo's Avatar
denbo
I need one lads anyone got with no knock sensor on it ?
Old Apr 7, 2008 | 09:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
"10psi. "
Is it not only the 90spec (hearts and diamonds) ECU's that allow up to 10psi?
Denbo i think even if it has a knock sensor you can just unplug it mate.
Old Apr 7, 2008 | 09:54 PM
sm's Avatar
sm
red blue white is actually a s2 ecu with no knock sensor
blue red blue is a s1 ecu
all erst ecus can run roughly 8 psi as std apart from a 90 spec one which can run 10 psi
unscrew the back of the ecu then unsrew the board from the casing then turn it over and have a look at the chip, if its a aftermarket one it should have a sticker on it saying which company fitted it if ur not sure then post up a pic of it on here
Old Apr 7, 2008 | 11:18 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
I've got a blue/red/black ecu up for grabs?
Old Apr 8, 2008 | 05:33 AM
T28 RST's Avatar
T28 RST
Ok then
PM sent
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
griffo69
Oct 4, 2015 11:58 AM
RSmark84
Sep 13, 2015 01:29 PM
