Advice on Evo ownership
Old Apr 6, 2008 | 06:16 PM
Nick b's Avatar
Nick b
Default Advice on Evo ownership
Really thinking of selling my 450 bhp S4 and getting and EVO 6.
Not sure if i am bein mad or not.
But would like some pro's and con's for the EVO 6 plz
Thanks
Nick
Old Apr 6, 2008 | 06:18 PM
Dicko&Vacant's Avatar
Dicko&Vacant
i wouldnt have an evo 6 over your car atm tbh mate,
theyre quite bad on petrol, not that impressive standard either, not what youd expect them to be from my opinion, i was underimpressed with mine plus your Audi looks a lot better than an Evo 6!
Old Apr 6, 2008 | 06:19 PM
danneth's Avatar
danneth
TORQUE!
agreed
Old Apr 6, 2008 | 06:20 PM
Azrael's Avatar
Azrael
Depends on what you need your car for.
Evo 6 is a very very very quick car around corners, but not really suited for blasting down a dual carriageway like your current motor.
Old Apr 6, 2008 | 07:05 PM
Have deep pockets cause the bits arnt cheap.
Old Apr 6, 2008 | 09:07 PM
Azrael's Avatar
Azrael
One must have a spare transfer box in the garage ;(
Old Apr 6, 2008 | 09:10 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
only found good points at the minute for my7 apart from the fuel i would have a evo over the audi anyday far more fun to drive its all about corners with a evo
Old Apr 6, 2008 | 09:27 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Thanks
Nick
Keep the Audi mate. Mad to chop that for an Evo.
Old Apr 6, 2008 | 10:04 PM
jameswrx's Avatar
jameswrx
You must have had one shonky evo 6! Most of the evo posts that come up involve a reply about how bad yours was lol.. begs the question why you bought it really?
I guess it's like anything really, good and bad cars in every make/model.
A 450bhp S4's gotta be a stonking straight line monster! As others have said though, depends what sort of driving you like. Remember the Evo 6 is nice and easy to get a reliable 350bhp+ out of, that'll still be a nippy motor with amazing handling. The evo won't set your pants alight standard, but get one that's been tuned nicely and it'll put a grin on your face.
Old Apr 6, 2008 | 10:11 PM
as355f1's Avatar
as355f1
I done the opposite, sold me evo 7 and bought an S4, would defo not go back unless i was doing track days every weekend, and the servicing costs were horrendous, front pads trade Ł225, and a diff service every 4500 miles @ Ł200 a pop and 15mpg oh and clutches every 10k, and you have to put up with looking like a chav twat evertime you drive it, but on the plus side i used to keep up with bikes.
Old Apr 6, 2008 | 10:14 PM
as355f1's Avatar
as355f1
here is my baby
Old Apr 6, 2008 | 10:16 PM
as355f1's Avatar
as355f1
and me evo 6 i had b4 me 7
Old Apr 6, 2008 | 10:18 PM
Dicko&Vacant
i bought it to see what the hype was about. Think ill stick with Cosworths from now on
Bought mine damaged so that didnt help, but tbh had i bought it undamaged itd have been even worse i reckon, i just had no interest in it unfortunately.
I think its right what people say, theyre a car for corners, but its a fact the roads do not consist of only roundabouts
Old Apr 6, 2008 | 10:27 PM
jameswrx's Avatar
jameswrx
Maybe you forgot to put the turbo back on when repairing the damage
I've had a few evo's and I had a relatively std evo 6 (exhaust and filter) that made 315bhp on the rollers and was a quick car. Had one with a few more mods and power FC that made circa 350bhp mapped by abbey m'sport and it was a very fast road car.
On the flip side I bought a 5 the other day and it was slow as fook! Put a boost gauge on it though and it was making fook all boost. Found a few problems (dv leaking off, plugs shafted, split hose etc) and sorted them.. she's now up to std power and goes better. I'm gathering the parts for 350bhp min and then I know it'll be a nice quick road car.
Old Apr 6, 2008 | 10:39 PM
jameswrx's Avatar
jameswrx
Ł225 for pads, trade
Ł200 for 'diff service'
Sheesh, they saw you coming Was that Mitsubishi? robbing fecks charged me Ł100 a few years ago for an AYC fluid change. I do it myself now.
I had (a supplied) new rear diff fitted, new gear oil, new AYC cluth bath fluid, new AYC pump fluid and AYC bleed for Ł90 form an Evo specialist! I do the AYC clutch bath change myself for about Ł7! just get the stuff from Mitsubishi or dexron III atf from motorfactors.
I do like the S4's and may well have one in the future. I'm suprised they are cheaper to run! I suppose I've steered clear of Mitsubishi dealers mostly and there's a specialist evo garage near me that's very cheap.
Old Apr 6, 2008 | 10:44 PM
as355f1's Avatar
as355f1
The pads were from Andrew page trade to me as i own a garage and i did not have the bleed system to do the AYC and no specialist in Newcastle so had to use the main steeler
Azrael's Avatar
Azrael
You may want to buy good synthetic fluid for AYC hydraulics - like Castrol transmax Z
Old Apr 6, 2008 | 10:45 PM
Azrael's Avatar
Azrael
You don't need anything else but a wrench to bleed the system (plus some know-how)
Old Apr 6, 2008 | 11:01 PM
as355f1's Avatar
as355f1
eh yes you do if you want it done right
You need to run the ayc pump while putting in the fresh oil and bleed the whole system or you wont get all the old oil out and you will end up fooking the diff and at Ł4500 a go i decided to play it safe and get the main dealers to do it
would like to know how you do it with a spanner and some know how ?
Old Apr 6, 2008 | 11:07 PM
Azrael's Avatar
Azrael
It takes more time then with MUT, but it is doable.
Old Apr 6, 2008 | 11:20 PM
as355f1's Avatar
as355f1
sorry but unless you have got the proper bleed system that the main dealers have (MUT II)there is no way you can be sure its done right as you cant run the pump and get it out of there without there tool, unless you run the car on a ramp while your doing it but then you run the risk of burning the AYC clutch plates out if you run them dry of oil,Plus you need to reset the ecu and all air MUST be bleed from the system just not worth the risk IMHO, and mitsi know how shite they are thats why they insist on a service every 4500 miles
You will be lucky to get 30k out of a diff if its not serviced as per dealer requirements and i have seen loads of fooked ones !
Old Apr 7, 2008 | 12:36 AM
Azrael's Avatar
Azrael
OK, I won't argue, you know better.
Luckily tens of Evos around me don't know that.
Old Apr 7, 2008 | 01:26 AM
15D's Avatar
15D
Italian convert
Spend 5k wisely on an Evo and you end up with a car that, if correctly assembled/mapped, will push out nigh on 500bhp/450+fllb and give you 30k miles of just routine servicing.
Spend 5k on a Cos and you get 400/400 and WILL get to know an RAC/AA man within 20k miles for DEFFO!
Your Evo must have been a shitter or you like motorway blasting or both!
Old Apr 7, 2008 | 05:45 AM
Redkop's Avatar
Redkop
APMSL - didn't they just.... at the cost of pads. I have just ordered some brand new, standard front discs AND Brembo pads for my Evo VIII for Ł120 delivered! HERE
I have never paid anywhere near as much as Ł200 for a full service either, which includes changing all oils [engine, transfer box, g/box & SAYC et al] and new filters.
An Evo is no different on fuel to any other high perf car if it's driven hard all the time.
Old Apr 7, 2008 | 06:03 AM
jameswrx's Avatar
jameswrx
Regarding the AYC fluid..
The clutch bath fluid and the pump system are 2 separate systems. The clutch bath fluid is a simple drain and fill on the rear diff. The pump system is separate and the reservoir in the boot is part of it. The only part you need to change every 4,500 is the clutch bath fluid.
I have written an idiots guide to this in the technical archieve on the MLR.
The pump system shouldn't get dirty and even mitsubishi have gone up to 18k interval on this part.
Old Apr 7, 2008 | 07:35 AM
Dicko&Vacant
tbh tho a 315bhp 4x4 aint quick when your used to a 450bhp 2wd, it was a significant lack of power or general excitement.
Old Apr 7, 2008 | 08:54 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
I agree with the mpg when driven hard it's the crap mpg when driving economically that gets me they really struggle to 20 mpg but that's probably the 100bhp they need tor drive the oil pump to the 8 bar or so they run
Old Apr 7, 2008 | 09:08 AM
Redkop's Avatar
Redkop
Driving on a long distance run to TOTB in 2006 when the car was only running 300bhp, I managed to get 290 miles to a full tank [55 litres] and I wasn't hanging about either. The benefit of having a 6th gear helps....
Old Apr 7, 2008 | 06:02 PM
Red16's Avatar
Red16
not Mitsi specialists but they're a performance car setup... AS Performance in Birtley
ive NEVER had more than 200 miles out of a full tank with my Evo V
theyre not that impressive in a straightline in standard form, with a remap theyre a lot better but theyre just too well planted/comfortable/heavy/4x4 to feel raw and fast with only 350ish bhp, so i understand why you were a little bemused with the performance side of things, especially looking at the previous 450bhp 2wd cossie you owned, lol. But theyre fantastic to drive round bends n country roads etc
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
