Fitting a aftermarket breather
Does anybody have any pics/diagram of where to have hoses etc. Im just bit puzzled as theres the pipes that go to the cooler that the oil filter mount to etc but also the oil pipe that goes to the bottom of the block near there. What do i need to do?
the 2 tops outlets go to the rocker outlets,1 of the bottom outlets goes to block and the other goes to metering head or to a catch tank,sit it in place and youll see it better,do you have the fitting kit with it,and dont attach it to the oil cooler,thats water thats going thru that
thats excellent help thanks mate. i don't have a fitting kit just got a load of braided hose that im cutting to length.
If i use a catch tank, im guessing i just block off the part on the metering unit yeah? is that the part next to the outlet that a vacuum pipe goes to from the amal valve?
JoeyBoyden
Aug 18, 2015 10:52 PM
