help , cams on a zetec? what side up is tdc?
Old Apr 6, 2008 | 10:53 AM
luke89's Avatar
luke89
Team HOTHOT!
Default help , cams on a zetec? what side up is tdc?
hi people , iv forgot what way up TDC is on my cams i market it up but then cleaned it and forgot were the marks went if any one has any pics of there cams at TDC with the cam cover off that would be awsome if no any one no how to tell ? really dont want them 180o out
thanks
Old Apr 6, 2008 | 11:19 AM
mark_24v_wiring's Avatar
mark_24v_wiring
put the camshaft locking tool in the back side of them it only goes in when there in the right place.
If you not got one you need a 5mm thick flat metal plate that fits into both cams at the same time
Old Apr 6, 2008 | 11:27 AM
DazC's Avatar
DazC
180 degrees out won't matter....
Cranks do 2 revolutions to 1 revolution of the cam so that means that when the crank is back at TDC, the cams have only moved 180 degrees anyway.
Just get the Zetec cam locking tool as above...
dave1960
Ford Fiesta
Sep 16, 2015 11:34 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Chopshop85
Sep 12, 2015 06:42 PM
grishenko45
Sep 9, 2015 12:58 PM
rog
Sep 4, 2015 07:24 AM
