FRS Boost problem.
Old Apr 5, 2008 | 09:57 PM
frenchfry's Avatar
frenchfry
Default FRS Boost problem.
Got a bit of a problem, just been out in my car, happily going along making a bar of boost, came off a roundabout in 2nd, changed to 3rd and I have no boost at all, the car is driveable, just, but has absolutely no power.
All the boost hoses are on, none are split, there were no funny noises, bangs or clunks, it just now has no power.
What could be the problem?
Old Apr 5, 2008 | 11:27 PM
KSA-Cossie's Avatar
KSA-Cossie
Check the boost solenoid m8.
Old Apr 5, 2008 | 11:54 PM
frenchfry's Avatar
frenchfry
sorry for the muppet questions, but where is it and how do I check it? cheers
Old Apr 6, 2008 | 04:30 PM
cootsie's Avatar
cootsie
sound like your car has gone on to limp mod. Try disconnection the battery for 15mins to reset the ECU..
When you connect the battery leave it running with maybe the lights and the fan on for 10 mins and then take it a run. It will have to learn again...
Old Apr 6, 2008 | 04:47 PM
justin2's Avatar
justin2
ive had this before mate and it was a knackered plug lead?
Old Apr 6, 2008 | 04:49 PM
lankypicker's Avatar
lankypicker
try this first
Old Apr 6, 2008 | 07:34 PM
frenchfry's Avatar
frenchfry
Fixed it, actuator rod had come off the wastegate, popped it back on and it's making boost again.
Need to get a clip back on it tomorrow though, so it doesn't do it again.
Old Apr 6, 2008 | 10:04 PM
lankypicker
cool
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
