cossie idle valves
Old Apr 4, 2008 | 07:05 PM
cosworthbs's Avatar
cosworthbs
Default cossie idle valves
When these things go wrong where can you get new used ones from apart from ebay or cossie breakers.
Old Apr 4, 2008 | 07:15 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
stick it in some diesel over night..........then try it
Old Apr 4, 2008 | 07:17 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
new used ones?
what like brand new second hand
Old Apr 4, 2008 | 07:20 PM
JTECH James
Passion for Fords!
thats fantastic advice,as the valve will hold some diesel,and induce it into the air stream.....det anyone
Old Apr 4, 2008 | 07:23 PM
cosworthbs's Avatar
cosworthbs
Ha Ha , i have seen the mistake.
Old Apr 4, 2008 | 07:24 PM
Dicko&Vacant's Avatar
Dicko&Vacant
im sure a1 sell new ones
Old Apr 4, 2008 | 07:26 PM
JTECH James
Passion for Fords!
lancia use the same valve.....pj motorsport had a few brand new ones at 200 quid....
Old Apr 4, 2008 | 07:29 PM
cosworthbs's Avatar
cosworthbs
Thumbs up
Thanks i will give them call
Old Apr 4, 2008 | 08:40 PM
pete mcrash
..........oh i forgot about twats like u........sorry i should have said let it dry and apply a little oil in the "sprinngy bit"......
Old Apr 4, 2008 | 08:49 PM
JTECH James
Passion for Fords!
what oil? theres one common type you should NEVER use......
but twats like you wouldnt know which,or why......
Old Apr 5, 2008 | 07:07 AM
pete mcrash
..................................why dont u fukin' tell him then.....gobshite...
Old Apr 5, 2008 | 07:26 AM
pete mcrash
are u talking about wd40.......cos there's been a thread on here,and people say thats what they use with no problems..........i used a dribble of engine oil......(if thats ok with u..??)
Old Apr 5, 2008 | 08:43 AM
JTECH James
Passion for Fords!
wd40 should never be used, because,as any intelligent person will tell you,it evaporates in a few hours,and leaves a grease like residue....making the valve sticky.
a thin oil is best.
and the best thing to clean them with is a solvent based cleaner like carb cleaner,as it evaporates away to nothing,
but its fact that 90% of so called iscv problems,are not directly related to the valve itself....people seem to think a surging idle is a iscv fault....but that normally means the valve is working perfectly well,rasing and lowering idle......its an engine setup fault more often
Old Apr 5, 2008 | 09:07 AM
pete mcrash
what about........olive oil (extra virgin)....thats pretty thin.......or maybe tea tree oil....thats thin as fuck.........
Old Apr 6, 2008 | 04:08 PM
cosworthbs's Avatar
cosworthbs
Everybody getting on well together as usual then. Thanks to you both for the info.
Old Apr 6, 2008 | 07:11 PM
Ha ha pete nice one hee hee.
Old Apr 6, 2008 | 07:16 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
whats it doin? not the tps is it?
15
Oct 7, 2015 03:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RSmark84
Sep 13, 2015 01:29 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
