Ford Plastic Fuel Pipe & Pressure Connectors
Old Apr 4, 2008 | 02:20 PM
Ryan's Avatar
Ryan
Default Ford Plastic Fuel Pipe & Pressure Connectors
Any one how they get the plastic pipe over the connection? is it a heat up job and the allow it to cool?
Basically just got a escort cossy rail and line and didnt realise they were plastic cover in rubber hose, thought they were just rubber, so now i need to somehow convert the end to 3dr items (if possible) sure it is with a bit of jiggery pokery.
so any suggestions welcome, and also anyone got 2 3dr fuel line pressure connectors as the escort ones are different
Old Apr 4, 2008 | 04:16 PM
Ryan's Avatar
Ryan
anyone?
Old Apr 4, 2008 | 04:19 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
to get the pipes off the rail,its 30secs with a hot air gun....
Old Apr 4, 2008 | 04:26 PM
Ryan's Avatar
Ryan
can a pipe be cut though and put onto another connector?
Old Apr 4, 2008 | 04:28 PM
JTECH James
Passion for Fords!
id go aeroquip now
Old Apr 4, 2008 | 05:24 PM
Ryan's Avatar
Ryan
dont really want to quip the rail, prefer the standard rail, but want the escort one as its so much neater than the 2wd item, but if i have to i'll go back to a standard 2wd item or maybe a billet one aga in (just sold one)
Old Apr 4, 2008 | 05:29 PM
JTECH James
Passion for Fords!
could you not take it to a hose place,i know a few here in devon,pressurelines,or pirteck could sort it out...they will have special equipment to do it...
Old Apr 4, 2008 | 05:31 PM
rsnissan's Avatar
rsnissan
i have the standard connections on the I think you can buthcer them if you need to
Old Apr 4, 2008 | 05:35 PM
JTECH James
Passion for Fords!
its fookin risky though,,just think if one comes off on boost,you got 6bar fuel pressure in the bay...
Old Apr 4, 2008 | 05:51 PM
Ryan's Avatar
Ryan
there's a way to get them on and off the, so should be fine, as they work on pressure.
andy, that would be great if you can get it off ok?
think i've got one on my rail still so that would be the 2 i need.
The other option is to somehow join the plastic to the metal pipe via some for of rubber joiner.
Old Apr 4, 2008 | 08:01 PM
rsnissan's Avatar
rsnissan
give me a call tomorrow as i took my fuel lines off with it all connected when i quiped the lot so should still be on the end still.
Old Apr 4, 2008 | 09:50 PM
Ryan's Avatar
Ryan
great cheers mate
up for the evening peeps
Old Apr 5, 2008 | 09:45 AM
Ryan's Avatar
Ryan
Bailes1992
Aug 16, 2015 07:14 PM
muz
Aug 16, 2015 12:57 PM
muffster
Aug 12, 2015 08:14 PM
M K
Aug 12, 2015 06:57 PM
