2 quickies................
Old Oct 22, 2004 | 11:28 AM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
Default 2 quickies................
cant find links so someone help us out please............
1) fuel pressure on idle (950rpm) vac disconnected
2) can you reset co pot on level 6 ecu? if so how?
Thankyou please
Old Oct 22, 2004 | 11:31 AM
Jim Galbally's Avatar
Jim Galbally
std: 3.2-3.8 bar (i recon that means 3.5bar... lol)
chip could very well be mapped for a different pressure tho...
check with the chip manufacturer what FP and idle CO it should be set to...
Old Oct 22, 2004 | 11:34 AM
dannyblackpool
Boost Builder
set standard jim thats why i put standard
Cheers you cossie guru you
Co pot??????
Old Oct 22, 2004 | 11:39 AM
Stu @ M Developments's Avatar
PassionFords Creator
1) 3.5bar. Vac pipe disconnected.
2) Turn Co pot 4 turns clockwise and then 2 turns anti clockwise to get somewhere around the base position of zero multiplication.
3) Wheres my brew?
Jim Galbally
dunno how to reset it, surely you just bung car on gas anyliser and adjust till it hits std setting
know wot u mean tho, i rememebr on my old XR4x4 you'd unscrew it exactly 2.5turns to get back to "base" setting
feck knows wot it is ona cossie tho...
also...
did you?
Thankyou please
oh look, you didn't
dannyblackpool
Boost Builder
ill make ya one in bit if i get chance
Old Oct 22, 2004 | 11:41 AM
dannyblackpool
Boost Builder
oops forgot
Old Oct 22, 2004 | 11:42 AM
Jim Galbally
hehold jim, cossie tuning GOD!
ALL HAIL JIM
ALL HAIL JIM
ALL HAIL JIM
dannyblackpool
Boost Builder
No fears Danny.. il prob be out anyway, fooking stacks of external aggro to attend to today pal
Old Oct 22, 2004 | 11:43 AM
dannyblackpool
Boost Builder
actually jim that was f stu
Old Oct 22, 2004 | 11:44 AM
Jim Galbally
damit, if stu wasn't online i'd have looked really clever there too
difference between stus anser and mine is that i had to look it up and stu just knew
im almost as good a tuner as ima now i recon!
Old Oct 22, 2004 | 11:46 AM
Originally Posted by Jim Galbally
i had to look it up
Funniest and truest fooking thing ive read all week
In fact.. ere.. take it Jim
Old Oct 22, 2004 | 11:49 AM
Jim Galbally
was it funny enough to put you in a good enuf mood to do a str8 swap for your car and mine?
Old Oct 22, 2004 | 12:00 PM
No problem at all Jim.... just shove £6K in the boot in used notes and drive on over in her
