T38 v T34
Old Apr 3, 2008 | 10:13 PM
big mac's Avatar
big mac
Default T38 v T34
Wot u thoughts pros and cons on st3 saff 4x4
Thanks in advance
Old Apr 3, 2008 | 10:19 PM
Gordon1's Avatar
Gordon1
Thanks in advance
a t34 is a nice turbo for a road 330bhp
Old Apr 3, 2008 | 10:20 PM
15D's Avatar
15D
Italian convert
T34 = great spool, 400bhp potential and will bolt onto a std motor, cheap
T38 = slightly laggy in comparison but bigger top end hit , 480?bhp potential but will surge like hell unless you have a ported head, expensive
Old Apr 3, 2008 | 10:24 PM
4x4pete's Avatar
4x4pete
From what i know theres a few ppl who do there own kind off t38.
I had a T34 and found it ran out of puff about 6000rpm but my T38 pulls like a train i would never look back
Old Apr 3, 2008 | 10:27 PM
big mac's Avatar
big mac
Wot hp u running though pete standard engine?
Old Apr 3, 2008 | 10:28 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
There is the Universal Turbo's T38 that is based on a T34 frame with machined housings etc, meant to be good for approx 440ish with almost T34 spool-up
then there is the Turbo Technics T38 that is a T4 frame but slightly smaller housing a/r's and wheels etc. Meant to be good for 470ish approx with bit better than T4 spool-up.
Unless you want to push a genuine 400BHP +, and have the headwork to cope with it then stick to a T34.48
Old Apr 3, 2008 | 10:29 PM
big mac's Avatar
big mac
Is ur's turbo technics?
RWD_cossie_wil
Nope UT
Old Apr 3, 2008 | 10:52 PM
FIESTA CHRIS H's Avatar
FIESTA CHRIS H
how do you mean
Old Apr 3, 2008 | 10:56 PM
RWD_cossie_wil
Originally Posted by FIESTA CHRIS H
how do you mean
it will create more air than the engine can consume, so will cause back pressure to be felt by the compressor, and you get a horrid situation of the turbo speeding up and slowing down very quickly.
Old Apr 3, 2008 | 11:04 PM
FIESTA CHRIS H
thanks for the explanation
Old Apr 3, 2008 | 11:22 PM
Staffi's Avatar
Staffi
Have to agree, i've had both UT T38 and a T34.48 and i must say the latter was awesome for a road car, peaking @ 32 psi it spooled up fantastic, where as the 38 was laggy in comparison..
Old Apr 3, 2008 | 11:34 PM
big mac's Avatar
big mac
Thanks 4 advise chaps stick with the 34 then
Old Apr 4, 2008 | 12:11 AM
NEIL A's Avatar
NEIL A
I have a UT T38 on my car just now im just running in so set to 12 psi max, its making posative boost around 2200 rpm and 12psi before 3000rpm.
Cosnada
Jan 7, 2016 05:30 PM
Russ Payne
Sep 25, 2015 08:29 PM
28
Sep 8, 2015 07:10 PM
