Track Preperation?
Im halfway through track preping my fiesta rs1800.
Ive fitted two Sparco Touring Carbonaro seats, removed the rears. Sorted the engine out etc
Im after a few more ideas for whats essential for track day. Bare inmind im still using it to get to work.
Im going to remove some bits on my dash that are not needed then flock it, how do i go about flocking?
ideas please
thanks matty
ideas please
thanks matty
how long is your commute??! can lighten doors, remove metal from inner rear quarters, get poly-carb windows.......spare set of wheels for track days with some proper tyres is a good idea.
a work colleague is building a rally car and used Nextel paint instead of flocking as it's cheaper. it was Nasa comissioned for use on instrument panels in space shuttle so it's pretty darn matte
chris
chris
my treck to work can vary being a electricain, all i ment was it need to be road legal.
im ordering carbon doorcards to keep it neat rather than no door cards at all. Cutting out the glove box and other bits of the dash i dont need before i cover it. Have you got a picture of the nextel dash?
im also taking out the carpet but putting acoustic carpet down (stuff that you use on subs) to keep the noise at a reasonable leval, if it doesnt work ill just rip it out again for weight.
Also removing the headlining etc
trying to source brakes through ebay, ive found some by WMS (works motor sport) which fit under 15's and are around Ł300 new so i might go for them to save me waiting for used ones to pop up
also got my eye on some other bits
will see if i can get some pictures of the nextel dash.
ref: flocking - it needs to be carried out by a specialist as it involves firing electrostaticly charge fibres at the dash at high pressure.
SMILER258
Sep 28, 2015 09:04 AM
ossie cossie
Sep 21, 2015 05:07 PM
